Sonos login problem
Sonos login problem
Unread postby Baldrdk » 31 Aug 2017, 16:06
Madsonic version: MADSONIC 6.3.9560.8df1ddd.20170712.0605
Sonos Version: Latest (7.4 (version 37244160)) for the SONOS connetc.
I have had Madsonic up and running on my sonos, but now it wont work.
When i choose the Madsonic service in sonos, it seaches for a while and then displays "could not browse music" or something like that, it is in danish.
I have tried removing the service and installing it again. (android app)
I can chose the Madsonic service in list of services, and the name of this changes if i change the name, so i'm guessing that it is found corectly.
I can then enter the credintials and it works a while before telling me. There was a problem adding the service, and could not connect to server.
On the windows 10, i can add the service again. But i'm back to "could not browse music" message.
I'm thinking that this happened with an update of either Madsonic or sonos.
Any sugestions?
Baldrdk
Re: Sonos login problem
Unread postby Baldrdk » 06 Sep 2017, 09:13
No one else has probelms connection to their sonos lately?
Baldrdk
Unread postby Baldrdk » 14 Sep 2017, 19:24
Well I figured it our..sort of.
For anyone else haveing similar problems.
I factory reset my sonor, and imported all my music resourses again, including madsonic.
And it worked without problems.
Baldrdk
Return to Support 6.x
Users browsing this forum: No registered users and 4 guests
