Premium License not working
Unread postby techchad » 26 Sep 2017, 13:48
I purchased my Premium license a few days ago, when I try and add the license it says it works, but if I refresh the page it doesn't appear to keep the key. The Buy Premium link stays and if I restart the service the key is gone. I also tried resending the key via (http://beta.madsonic.org/backend/requestLicense.view) and it says my email doesn't have a license associated. Help?!?!
techchad
Re: Premium License not working
Unread postby matluma » 11 Oct 2017, 23:28
Any responses?
I am also having the same issues.
Have not had any support from MS crew. looking for alternatives that work.
matluma
Unread postby modestos » 25 Jan 2018, 19:47
I have the same problems from time to time with the beta program.
The beta license keeps getting invalid after some time so I have to contact Madevil to fix this.
mod
modestos
Unread postby Madevil » 25 Jan 2018, 23:07
To check your current Madsonic license status:
http://beta.madsonic.org/backend/licenseStatus.view
Has thanked: 1339 times
Return to Support 6.x
