HTTP ERROR: 503
HTTP ERROR: 503
Unread postby loggerhead » 16 Nov 2017, 06:38
I just installed Madsonic 6.3.9720 onto a Vortexbox machine (Fedora 20 flavor). The machine had subsonic installed, but I uninstalled that. I can't seem to get the webpage to load after install, I get a 503 error. Service is running.
HTTP ERROR: 503
Service Unavailable
Uncertain where to go from here. Here are the logs from /var/madsonic/
Nov 16, 2017 12:19:54 AM org.springframework.context.support.ClassPathXmlApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1d451d2: startup date [Thu Nov 16 00:19:54 EST 2017]; root of context hierarchy
Nov 16, 2017 12:19:54 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
Nov 16, 2017 12:19:54 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@13ab52c: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
No newer update found.
Extracting webapp to /var/madsonic/jetty/9720
2017-11-16 00:19:54.871:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2017-11-16 00:19:54.904:INFO:oejw.WebInfConfiguration:Extract jar:file:/usr/share/madsonic/madsonic.war!/ to /var/madsonic/jetty/9720/webapp
2017-11-16 00:20:01.129:INFO:/:Initializing Spring root WebApplicationContext
[2017-11-16 00:20:02] [WARN ] [main] XmlWebApplicationContext - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerDao' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'daoHelper' while setting bean property 'daoHelper'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoHelper' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static org.madsonic.dao.DaoHelper org.madsonic.dao.DaoHelperFactory.create()] threw exception; nested exception is java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
[2017-11-16 00:20:02] [ERROR] [main] ContextLoader - Context initialization failed
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:334)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
   at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:638)
   at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:942)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:482)
   at org.madsonic.booter.deployer.MadsonicDeployer.deployWebApp(MadsonicDeployer.java:247)
   at org.madsonic.booter.deployer.MadsonicDeployer.<init>(MadsonicDeployer.java:102)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
   at org.madsonic.booter.Main.<init>(Main.java:46)
   at org.madsonic.booter.Main.main(Main.java:85)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoHelper' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static org.madsonic.dao.DaoHelper org.madsonic.dao.DaoHelperFactory.create()] threw exception; nested exception is java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
   at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:603)
   ... 49 common frames omitted
Caused by: org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static org.madsonic.dao.DaoHelper org.madsonic.dao.DaoHelperFactory.create()] threw exception; nested exception is java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
   at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:181)
   ... 58 common frames omitted
Caused by: java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
   at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
   at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
   at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
   at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Class.java:274)
   at org.springframework.jdbc.datasource.DriverManagerDataSource.setDriverClassName(DriverManagerDataSource.java:147)
   at org.madsonic.dao.HsqlDaoHelper.createDataSource(HsqlDaoHelper.java:109)
   at org.madsonic.dao.HsqlDaoHelper.<init>(HsqlDaoHelper.java:56)
   at org.madsonic.dao.DaoHelperFactory.create(DaoHelperFactory.java:41)
   ... 59 common frames omitted
2017-11-16 00:20:02.402:WARN:oejw.WebAppContext:Failed startup of context o.e.j.w.WebAppContext{/,file:/var/madsonic/jetty/9720/webapp/},madsonic.war
Caused by:
Caused by:
Caused by:
2017-11-16 00:20:02.434:INFO:oejs.AbstractConnector:Started @0.0.0.0:4040
Nov 16, 2017 12:20:02 AM org.springframework.remoting.rmi.RmiServiceExporter getRegistry
Nov 16, 2017 12:20:02 AM org.springframework.remoting.rmi.RmiServiceExporter prepare
INFO: Binding service 'MadsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.0.1:9412](local),objID:[0:0:0, 0]]]]
loggerhead
Re: HTTP ERROR: 503
Unread postby Madevil » 16 Nov 2017, 13:14
the error: Unsupported major.minor version 52.0 mean you don't have the latest JDK8 as your default Java runtime.
Check current version with:
java -version
Download and upgrade to latest JAVA JDK 8 : http://www.oracle.com/technetwork/java/ ... index.html
Info: http://beta.madsonic.org/pages/installation.jsp#rpm
Has thanked: 1339 times
Re: HTTP ERROR: 503
Unread postby loggerhead » 17 Nov 2017, 06:30
That worked. Thanks!
I had to upgrade my OS, which is probably a good thing anyway.
thanks again
loggerhead
Re: HTTP ERROR: 503
Unread postby VatsanM » 06 May 2018, 14:42
I have the same error on Windows 10. I upgraded to latest Madsonic without uninstall.
INFO: Loading XML bean definitions from class path resource [org/springframework/jdbc/support/sql-error-codes.xml]
May 06, 2018 9:35:12 AM org.springframework.jdbc.support.SQLErrorCodesFactory <init>
INFO: SQLErrorCodes loaded: [DB2, Derby, H2, HSQL, Informix, MS-SQL, MySQL, Oracle, PostgreSQL, Sybase]
2018-05-06 09:35:14.059:WARN:oejw.WebAppContext:Failed startup of context o.e.j.w.WebAppContext{/,file:/C:/madsonic/jetty/9080/webapp/},madsonic.war
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaScannerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, path, name, enabled, changed, mf_index, mf_type, mf_groupby, mf_timer, mf_interval from music_folder]; nested exception is java.sql.SQLSyntaxErrorException: user lacks privilege or object not found: MF_INDEX in statement [select id, path, name, enabled, changed, mf_index, mf_type, mf_groupby, mf_timer, mf_interval from music_folder]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1514)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:938)
at org.madsonic.booter.deployer.MadsonicDeployer.deployWebApp(MadsonicDeployer.java:243)
at org.madsonic.booter.deployer.MadsonicDeployer.<init>(MadsonicDeployer.java:100)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by:
at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.java:92)
at org.madsonic.dao.AbstractDao.query(AbstractDao.java:107)
at org.madsonic.dao.MusicFolderDao.getAllMusicFolders(MusicFolderDao.java:54)
at org.madsonic.service.SettingsService.getAllMusicFolders(SettingsService.java:2287)
at org.madsonic.service.SettingsService.getAllMusicFolders(SettingsService.java:2262)
at org.madsonic.service.MediaScannerService.doUpdateTasks(MediaScannerService.java:208)
at org.madsonic.service.MediaScannerService.init(MediaScannerService.java:77)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1640)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1581)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1511)
Caused by:
at org.hsqldb.jdbc.JDBCPreparedStatement.<init>(Unknown Source)
at org.hsqldb.jdbc.JDBCConnection.prepareStatement(Unknown Source)
at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1447)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:583)
Caused by:
org.hsqldb.HsqlException: user lacks privilege or object not found: MF_INDEX
at org.hsqldb.ExpressionColumn.checkColumnsResolved(Unknown Source)
at org.hsqldb.QueryExpression.resolve(Unknown Source)
at org.hsqldb.ParserDQL.compileCursorSpecification(Unknown Source)
at org.hsqldb.ParserCommand.compilePart(Unknown Source)
at org.hsqldb.ParserCommand.compileStatement(Unknown Source)
at org.hsqldb.Session.compileStatement(Unknown Source)
at org.hsqldb.StatementManager.compile(Unknown Source)
2018-05-06 09:35:14.137:INFO:oejs.AbstractConnector:Started @0.0.0.0:4040
2018-05-06 09:35:14.496:INFO:oejus.SslContextFactory:Enabled Protocols [TLSv1, TLSv1.1, TLSv1.2] of [SSLv2Hello, SSLv3, TLSv1, TLSv1.1, TLSv1.2]
2018-05-06 09:35:14.496:INFO:oejs.AbstractConnector:Started SslSocketConnector@0.0.0.0:4443
VatsanM
Re: HTTP ERROR: 503
Unread postby Matt Zornig » 06 May 2018, 15:08
VatsanM wrote:I have the same error on Windows 10. I upgraded to latest Madsonic without uninstall.
If you have the same Error, you could probably try the same Solution.
And please wrap your Logs in CODE-Tags, found here, when you write a post (which you can edit afterwards too).
Been thanked: 20 times
Return to Support 6.x
