Repost. Strange issues
Unread postby matluma » 07 Jan 2018, 01:39
Hi all,
I have just done a fresh install of my Qnap server and have some strange issues with Sonos and Madsonic.
Firstly, After i point MS to my music share and scan it, it shows album covers and i can click and play them so they look like they are in order but when I search I get no results for anything. It also shows 0 files in both of the statistics windows.
Secondly, my Sonos is on FW 8 and this broke MS-Sonos untul the update.
I can get Sonos now to see MS with the workaround but there is no search feature available in Sonos either. I can only browse and it gets laggy.
Any ideas?
Just updated to latest new version and still no good here.
Does anyone know how to downgrade SONOS to 7.x firmware?
Thx
matluma
matluma
Re: Repost. Strange issues
Unread postby Madevil » 07 Jan 2018, 12:04
matluma wrote:Hi all,
Any ideas?
Thx
matluma
If you add new media folders to Madsonic, only a quick scan is performed. Before the entire search index can be used, a complete scan must be performed. Settings > Media Tools > Normal Scan
The new 6.3 Madsonic test branch is complete compatible with the Sonos 8.x firmware. :)
BTW Sonos don't allow to downgrade your Sonos firmware. :cry:
Has thanked: 1338 times
Unread postby fnzeee » 01 Mar 2018, 19:48
Hi, I also have MS installed on a production qnap, but I have v6.2 installed. As a premium user, I am excited to enable the integration with Sonos. Correct me if I am wrong, but isn't the 6.3 release still considered beta (the download page still carries a warning that it is only to be used in test and not production environments)? If so, I will have to wait for it to be promoted as we run a production environment.
fnzeee
Unread postby Matt Zornig » 06 May 2018, 04:07
fnzeee wrote:Correct me if I am wrong, but isn't the 6.3 release still considered beta (the download page still carries a warning that it is only to be used in test and not production environments)? If so, I will have to wait for it to be promoted as we run a production environment.
stable 6.2.9040
beta 6.2.9080
alpha 6.3.9840
The Serverlog tells, 6.3 is an Alpha Version. I belive that, because I installed and tested it ;-)
[2018-05-05 20:53:32,551] DEBUG VersionService - Resolved latest Madsonic alpha version to: 6.3.9840
For me, it behaves more like a beta, but I wouldn't dare to install it on a productive enviroment.
Been thanked: 19 times
Return to Support 6.x
