Session timeouts do not redirect to login screen
troycarpenter
Has thanked: 28 times
Been thanked: 50 times
 VERSION:      MADSONIC 6.0 | BUILD: 7160
 SERVLET:      JETTY 8.y.z-SNAPSHOT
 SERVER:       CPU: AMD
 OS:           Linux MINT (DEBIAN/Ubuntu)
 SYSTEM:       CLIENT
 INSTALLER:    DEB | RPM | DOCKER | OTHER
 JAVA:         1.7.0_79
 BROWSER:      CHROME 45
 CLIENT:       MADSONIC 5.7.364
 DESCRIPTION:  LDAP not supported
 REPRODUCIBLE: YES
When my login session times out on the web GUI, instead of being redirected to the login screen, the content panel in the middle of the page shows a "broken webpage" symbol. At that point I have to reload the entire site, which then redirects me to the login page and everything works again.
Has thanked: 11 times
Been thanked: 105 times
Re: Session timeouts do not redirect to login screen
Unread post by gurutech »
I'm using Firefox, and don't have this issue. The timeout takes me back to the login page.
Nevermind.... happened to me....
troycarpenter
Sometimes the reloading of the page doesn't work. After this situation first happens, when I log in again I'm sometimes greeted with the broken page icon in all the panes (top, sides, middle, bottom). Sometimes a refresh cleans up one pane, but rarely all of them. Other times content shows but the styles are all wrong. I'm not exactly sure what causes it.
There have been times that a pop-up window appears complaining about some module should be loaded first. I'll have to capture that when it happens again.
I don't see any errors in the log (using debug level) corresponding to this.
Attached is a screen-shot of what I'm seeing. In this case, the top and bottom appeared, but the others did not...I've seen all variations of which panes are broken, from all to just one.
Broken pages after login.
