Madsonic encountered an internal error.
littledevil667
Been thanked: 11 times
Unread post by littledevil667 »
Error
Message PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: java.lang.IndexOutOfBoundsException; nested exception is java.sql.SQLException: java.io.IOException: java.lang.IndexOutOfBoundsException
Java version Oracle Corporation 1.8.0_66
Operating system Windows 10 10.0
Server jetty/8.y.z-SNAPSHOT
Memory Used 74 of 489 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: java.lang.IndexOutOfBoundsException; nested exception is java.sql.SQLException: java.io.IOException: java.lang.IndexOutOfBoundsException
at org.madsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:255)
at org.madsonic.service.MediaFileService.getMediaFile(MediaFileService.java:141)
at org.madsonic.service.MusicIndexService.createSortableArtistsforGenre(MusicIndexService.java:271)
at org.madsonic.service.MusicIndexService.getIndexedArtistsforGenre(MusicIndexService.java:148)
at org.madsonic.controller.LeftController.getMusicFolderContent(LeftController.java:349)
at org.madsonic.controller.LeftController.handleRequestInternal(LeftController.java:246)
Caused by: java.sql.SQLException: java.io.IOException: java.lang.IndexOutOfBoundsException
... 79 more
Caused by: org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException
at org.hsqldb.persist.DataFileCache.readObject(Unknown Source)
at org.hsqldb.persist.DataFileCache.getFromFile(Unknown Source)
at org.hsqldb.persist.DataFileCache.get(Unknown Source)
at org.hsqldb.persist.RowStoreAVLDisk.get(Unknown Source)
at org.hsqldb.index.NodeAVLDisk.findNode(Unknown Source)
at org.hsqldb.index.NodeAVLDisk.getLeft(Unknown Source)
at org.hsqldb.index.NodeAVLDisk.child(Unknown Source)
at org.hsqldb.index.IndexAVL.insert(Unknown Source)
at org.hsqldb.persist.RowStoreAVL.indexRow(Unknown Source)
at org.hsqldb.persist.RowStoreAVLDisk.indexRow(Unknown Source)
at org.hsqldb.TransactionManager2PL.addInsertAction(Unknown Source)
at org.hsqldb.Session.addInsertAction(Unknown Source)
at org.hsqldb.Table.insertSingleRow(Unknown Source)
... 84 more
Caused by: java.io.IOException: java.lang.IndexOutOfBoundsException
at org.hsqldb.lib.java.JavaSystem.toIOException(Unknown Source)
at org.hsqldb.persist.RAFileNIO.read(Unknown Source)
at org.hsqldb.persist.RAFileHybrid.read(Unknown Source)
... 102 more
Caused by: java.lang.IndexOutOfBoundsException
at java.nio.Buffer.checkBounds(Unknown Source)
at java.nio.ByteBuffer.get(Unknown Source)
at java.nio.DirectByteBuffer.get(Unknown Source)
... 104 more
