multiple played @ last.fm
jake-
Has thanked: 13 times
Been thanked: 15 times
Unread post by jake- »
transcoded song are submitted several times to last.fm:
[2016-02-05 14:09:01,250] INFO TranscodeInputStream - Starting transcoder: [/var/madsonic/transcode/ffmpeg] [-i] [/mp3/Motörhead/We Are Motörhead/07 - Motörhead - One More Fucking Time.flac] [-map] [0:0] [-b:a] [192k] [-v] [0] [-f] [mp3] [-]
[2016-02-05 14:09:01,274] DEBUG AudioScrobblerService - Successfully registered submission for song 'One More Fucking Time' for user xx at Last.fm: Fri Feb 05 14:09:00 CET 2016
[2016-02-05 14:09:01,979] DEBUG AudioScrobblerService - Successfully registered now playing for song 'One More Fucking Time' for user xx at Last.fm: Fri Feb 05 14:09:01 CET 2016
[2016-02-05 14:09:09,275] DEBUG StreamController - GET /stream?player=1&id=380366, Range: bytes=9766138-9767999
[2016-02-05 14:09:09,306] INFO PlayQueueInputStream - admin listening to "We Are Motörhead/07 - Motörhead - One More FuckingTime.flac"
[2016-02-05 14:09:09,309] INFO TranscodeInputStream - Starting transcoder: [/var/madsonic/transcode/ffmpeg] [-i] [/mp3/Motörhead/We Are Motörhead/07 - Motörhead - One More Fucking Time.flac] [-map] [0:0] [-b:a] [192k] [-v] [0] [-f] [mp3] [-]
[2016-02-05 14:09:09,360] DEBUG AudioScrobblerService - Successfully registered submission for song 'One More Fucking Time' for user xx at Last.fm: Fri Feb 05 14:09:08 CET 2016
[2016-02-05 14:09:10,202] DEBUG AudioScrobblerService - Successfully registered now playing for song 'One More Fucking Time' for user xx at Last.fm: Fri Feb 05 14:09:09 CET 2016
[2016-02-05 14:09:17,170] DEBUG StreamController - GET /stream?player=1&id=380366, Range: bytes=9766138-9767999
[2016-02-05 14:09:17,222] INFO PlayQueueInputStream - admin listening to "We Are Motörhead/07 - Motörhead - One More Fucking Time.flac"
[2016-02-05 14:09:17,224] INFO TranscodeInputStream - Starting transcoder: [/var/madsonic/transcode/ffmpeg] [-i] [/mp3/Motörhead/We Are Motörhead/07 - Motörhead - One More Fucking Time.flac] [-map] [0:0] [-b:a] [192k] [-v] [0] [-f] [mp3] [-]
[2016-02-05 14:09:17,525] DEBUG AudioScrobblerService - Successfully registered submission for song 'One More Fucking Time' for user xx at Last.fm: Fri Feb 05 14:09:16 CET 2016
[2016-02-05 14:09:18,294] DEBUG AudioScrobblerService - Successfully registered now playing for song 'One More Fucking Time' for user xx at Last.fm: Fri Feb 05 14:09:17 CET 2016
[2016-02-05 14:09:21,289] DEBUG StreamController - GET /stream?player=1&id=380366, Range: bytes=9766138-9767999
[2016-02-05 14:09:21,290] INFO PlayQueueInputStream - admin listening to "We Are Motörhead/07 - Motörhead - One More Fucking Time.lac"
fm.tiff
Version MADSONIC 6.0.7960.c288541.20160122.0103 - IP address [10.10.0.117]
REST MADSONIC REST API v2.2.0, SUBSONIC REST API v1.15.0
Server jetty/8.y.z-SNAPSHOT, java 1.8.0_72, Linux 4.2.6-1-pve (amd64) (690.3 MB / 1.92 GB)
Size: Database: 669MB, Thumbs-Cache: 153MB, LastFM-Cache: 82MB, Lucene-Cache: 29MB
Spring.Framework v3.2.16, Spring.Security v3.2.9, HyperSQL DataBase v2.3.3
These users thanked the author jake- for the post:
sebass
Re: multiple played @ last.fm
Unread post by sebass »
I had this same problem. IF the HTML5 player requests a new stream if the connecting drops while playing, madsonic will treat it as a new play.
Version	MADSONIC 6.1.8120.eec5b6f.20160304.1253 - IP address [192.168.178.222]
Server	jetty/8.y.z-SNAPSHOT, java 1.8.0_60, Windows 10 10.0 (amd64) (283,7 MB / 637,3 MB)
Size: Database: 977MB, Thumbs-Cache: 45MB, LastFM-Cache: 33MB, Lucene-Cache: 43MB
Transcoder	ffmpeg version N-77704-g68eb208 (05.01.2016)
Copyright (c) 2000-2016 the FFmpeg developers
rolle
Unread post by rolle »
I have also this problem. Sometimes it scrobbles 4 times while listening the same track, sometimes more. Usual case is when I see one scrobbled just in the same second when I start playing, another scrobble after playing.
Fix coming? Now having to manually remove scrobbles afterwards.
rolle
Reporting back. Removed all the players and restarted Madsonic, seems to work now. Strange.
These users thanked the author rolle for the post:
rolle
Updated to the latest version. Getting a song scrobbled instantly it starts playing AND after it's done.
