Defined Shortcuts no longer replace source
madsub
Been thanked: 19 times
Unread post by madsub »
In Server 5 I am used, that a defined shortcut replaces the source in the left panel, e.g. if you define "Various Artists" as a shortcut, this artist is no longer listed at the source location.
In Server 6.1 Index-Menu, which seems to be the replacement for the the former panel on the left side, both are listet: The source and the shortcut.
