Madsonic+nginx+https = broken buttons
Unread postby StalkerNOVA » 15 Jun 2016, 08:31
If you place Madsonic as HTTP backend for nginx with HTTPS frontend you get broken button "Settings" in the left tab. But "Profile" has no problem.
This bug came from Subsonic.
Chrome DevConsole:
Mixed Content: The page at 'https:...' was loaded over HTTPS, but requested an insecure resource 'http:...'. This request has been blocked; the content must be served over HTTPS.
StalkerNOVA
Been thanked: 6 times
Re: Madsonic+nginx+https = broken settings button
Unread postby StalkerNOVA » 16 Jun 2016, 00:57
Same for ranking and recommendations.
StalkerNOVA
Re: Madsonic+nginx+https = broken buttons
Unread postby Madevil » 16 Jun 2016, 11:07
i setup a example enviroment as follow:
*) install Madsonic server with default settings
*) install or update nginx
*) create selfsign cert
cd /etc/nginx
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/nginx/cert.key -out /etc/nginx/cert.crt
*) edit nginx config
sudo nano /etc/nginx/sites-enabled/default
*) replace nginx config
server {
    listen 80;
server {
    listen 443;
    ssl_certificate           /etc/nginx/cert.crt;
    ssl_certificate_key       /etc/nginx/cert.key;
    ssl on;
    ssl_session_cache  builtin:1000  shared:SSL:10m;
    ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
    ssl_prefer_server_ciphers on;
    access_log            /var/log/nginx/madsonic.access.log;
    error_log             /var/log/nginx/madsonic.error.log;
    location / {
      proxy_set_header Host              $host;
      proxy_set_header X-Real-IP         $remote_addr;
      proxy_set_header X-Forwarded-For   $proxy_add_x_forwarded_for;
      # Fix the “It appears that your reverse proxy set up is broken" error.
      proxy_pass          http://localhost:4040;
      proxy_redirect      http:// https://;
      proxy_read_timeout  90;
*) restart services
sudo service madsonic restart
sudo service nginx restart
http://localhost
PS: i send you a PM with a newer Madsonic build with several bug fixes.
Has thanked: 1338 times
Unread postby StalkerNOVA » 16 Jun 2016, 14:58
Steps to reproduce:
  1. disable redirect from 80 to 443
  2. allow proxy from 80 to madsonic 4040
  3. open madsonic with admin user
  4. right click at settings and open in new tab
You'll get the following:
  1. For short time link https /settings.view will be opened
  2. Instantly you'll be redirected to http /adminSettings.view
With redirect enabled you'll get one more step and will be instantly redirected to https.
May be it would not be a problem without option for nginx (but it's the best practice if you don't ban frames completely):
add_header X-Frame-Options SAMEORIGIN;
StalkerNOVA
Unread postby StalkerNOVA » 21 Jun 2016, 06:54
There are lots of links directly to http... They got visible if you make separate logs for http and https at nginx...
Making Madsonic https behind nginx isn't a good idea because https overhead gets even bigger (Madsonic encode traffic to https, nginx decode it and encode it again to transfer to end user).
At 80 and 443 ports I've many other services so can't dedicate them to Madsonic directly. Other ports are not always available from corporate networks.
StalkerNOVA
Unread postby PurellAdvanced » 11 Oct 2016, 20:54
I've also been bitten by this issue. The workaround for Nginx (using proxy_redirect) doesn't work for me since I use Caddy server to reverse proxy to Madsonic, and it doesn't have an equivalent method to rewrite the Location header going back to the client. I'd hate to have to migrate back to Nginx or Apache just because of this, so a bug fix would be really appreciated.
Looks like Subsonic also has this problem and it even has an outstanding patch to fix it, maybe that could come in handy? (Patch #23 on Sourceforce, sorry I can't link it).
PurellAdvanced
Unread postby Madevil » 15 Oct 2016, 05:25
i will include that fix in the next 6.2 branch. :thumbsup:
Unread postby PurellAdvanced » 26 Oct 2016, 19:56
Thanks so much Madevil!
PurellAdvanced
Unread postby StalkerNOVA » 19 Nov 2016, 12:19
BTW "Settings" button do not work. "Userprofile" has no problem.
When you rate smth stars do not show new rating until you refresh page (or go somewhere else and than return back to the page).
StalkerNOVA
Return to Bug Reports 6.x
