Some User's Activity Not Showing In Log
Unread postby TastyJams » 07 Nov 2016, 01:23
As of build 6.2.8840, only some users activity show up in the serverlog. Some users do not show up at all, however I can see that they are active in the Transferstatus and Broadcast tabs.
TastyJams
Has thanked: 2 times
Been thanked: 21 times
Re: Some User's Activity Not Showing In Log
Unread postby Madevil » 07 Nov 2016, 09:36
This issue should be fixed with the last 6.2 version.
Has thanked: 1338 times
Unread postby TastyJams » 07 Nov 2016, 21:07
Madevil wrote:Hi there,
The issue is with build 6.2.8840
Upon further investigation, it appears the issue is with any user using the app. Any user that is streaming via the web browser shows up correctly within the log, however none of the app based streaming shows up in the log at all.
TastyJams
Unread postby TastyJams » 26 Nov 2016, 20:11
As of Build 8920, this is still an issue.
TastyJams
Unread postby TastyJams » 14 Dec 2016, 05:07
As of build 9040, this is still an issue.
TastyJams
Unread postby TastyJams » 24 Dec 2016, 02:22
As of build 9080, this is STILL an issue.
TastyJams
Return to Bug Reports 6.x
