Podcast Page Not Playing Correct Item
Posted: 07 Dec 2016, 15:51
Not sure how long this bug has been around, or if it's a database issue, but when going into the Podcast Page, going into an individual podcast, and trying to select an episode, the player will always queue up whatever happens to be in the recently added/newest episodes list.
Example > I have roughly 30 podcasts, each with 10 episodes saved in them. If I go into podcast B and try to play episode 3, then the 3rd newest podcast downloaded (as shown on the newest episodes) will play. It doesn't matter which main podcast page I go into, if I click any of the 10 episodes and play them, whatever corresponding 'newest' episode will play.
I recently did a full scan on the database but this issue is still persisting.
System Info:
Version MADSONIC 6.2.9000.d969b6e.20161206.1041 - IP address [192.168.1.100]
Server jetty/8.y.z-SNAPSHOT, java 1.8.0_101, Windows 10 10.0 (amd64) (165.4 MB / 464.5 MB)
Size: Database: 459MB, Thumbs-Cache: 70MB, LastFM-Cache: 47MB, Lucene-Cache: 10MB
I did an inspect on the button element and found this:
<i class="fa fa-play clickable icon custom-icon" onclick="top.playQueue.onPlayNewestPodcastEpisode(0)" title="Play"></i>
I think this could possibly be the problem as the onclick option is just trying to get PlayNewestPodcastEpisode, not necessarily from the menu item. The Play Next/Play Last buttons seem to reference the correct items to add, so I think it's just something with the play button onclick coding.
Hopefully this helps.
System Info:
