LastFM causing slowness in web player
Unread postby boco » 08 Dec 2016, 19:03
Version   MADSONIC 6.2.8920.912d081.20161125.0550
REST   MADSONIC REST API v2.5.0, SUBSONIC REST API v1.14.0
Server   jetty/8.y.z-SNAPSHOT, java 1.8.0_111, Windows 7 6.1 Service Pack 1 (amd64) (580.3 MB / 928.0 MB)
Size: Database: 575MB, Thumbs-Cache: 117MB, LastFM-Cache: 41MB, Lucene-Cache: 29MB
Transcoder   ffmpeg version N-82597-gd316b21 (21.11.2016)
Copyright (c) 2000-2016 the FFmpeg developers
It appears that lastfm queries may be causing slowness/delays in the web player. See log below. If you add up all the seconds between tracks it is not enjoyable to listen to a random selection of songs with multiple second delays. AND sometimes it never comes back causing all playback to stop until the service is restarted. Maybe allow the song to start playback before results are retrieved back??
Or it might not be Lastfm at all. :) But something isn't right!
 is streaming RAW "CD2. Vocal Track\10 - Gushi & Raffunk - Arabian Nights.mp3"
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::updateMediaFile::createOrUpdateMediaFile: 17330 ms: update media_file set folder=?,type=?,override=?,format=?,data=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,mood=?,bpm=?,composer=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=?, rank=? where path=?
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 3357 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   MultiService   fn::getFullArtistInfo took: 30099 ms
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4554 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4740 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4453 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4886 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4536 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4985 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM]   DEBUG   AbstractDao   fn::getTrackByName::namedQueryOne: 4342 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:53 AM]   DEBUG   MultiService   Starting getTopTrackArtists() id:221858 artist:Mystic Rythms Band limit:10
boco
Has thanked: 69 times
Been thanked: 30 times
Re: LastFM causing slowness in web player
Unread postby Madevil » 08 Dec 2016, 21:31
try to defrag your database (Settings > Media Tools > Defrag) and restart your service.
Activate fast access for your library. (Settings > Media folders > Fast access mode)
If you have a very large library don't set the last.fm toptrack filter to high (recommend lower than 40)!
Has thanked: 1281 times
Been thanked: 947 times
Unread postby boco » 09 Dec 2016, 02:25
Thanks, Installed the newest version full rescan and cleanup. Also turned off toptracks. Appears to be working much better now.
boco
Return to Bug Reports 6.x
