Exception when an LDAP user tries to visit the "Admin Panel"
Unread postby w1ll14m » 22 Dec 2016, 09:41
Hi!
Recently I started using LDAP (just because we can) and set my LDAP user to be an admin, so now when i logon as that user and go to settings/admin panel i get the following error:
I'm running: 20161208_madsonic-6.2.9040-standalone
Bug report:
 VERSION:      MADSONIC 6.2 | BUILD: 9040
 SERVLET:      JETTY
 SERVER:       CPU: AMD Phenom(tm) II X6 1090T Processor | ARCH: X86_64 | MEMORY: 16GB | HDD: 12TB
 OS:           Gentoo
 SYSTEM:       tower/desktop hardware
 INSTALLER:    standalone
 JAVA:         ORACLE JDK 1.7.0_17
 BROWSER:      chrome Version 55.0.2883.87 m (64-bit)
 CLIENT:       MADSONIC 6.2
 DESCRIPTION:  Exception when an LDAP user tries to visit the "Admin Panel"
 REPRODUCIBLE: YES
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [select id, music_folder_id, artist_all, artist_album, albums, genre, music_files, music_files_size, video_files, video_files_size, podcast_files, podcast_files_size, audiobooks_files, audiobooks_files_size from statistic_server]; java.lang.ArrayIndexOutOfBoundsException; nested exception is java.sql.SQLException: java.lang.ArrayIndexOutOfBoundsException
Java version   Oracle Corporation 1.7.0_17
Operating system   Linux 4.3.0-gentoo-wLLm-Custom-x86_64
Server   jetty/8.y.z-SNAPSHOT
Memory   Used 71 of 210 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, music_folder_id, artist_all, artist_album, albums, genre, music_files, music_files_size, video_files, video_files_size, podcast_files, podcast_files_size, audiobooks_files, audiobooks_files_size from statistic_server]; java.lang.ArrayIndexOutOfBoundsException; nested exception is java.sql.SQLException: java.lang.ArrayIndexOutOfBoundsException
   at org.madsonic.dao.AbstractDao.query(AbstractDao.java:107)
   at org.madsonic.dao.MusicFolderStatisticsDao.getAllFolderStatistics(MusicFolderStatisticsDao.java:40)
   at org.madsonic.controller.AdminSettingsController.referenceData(AdminSettingsController.java:74)
   at org.springframework.web.servlet.mvc.SimpleFormController.referenceData(SimpleFormController.java:218)
   at org.springframework.web.servlet.mvc.AbstractFormController.showForm(AbstractFormController.java:578)
   at org.springframework.web.servlet.mvc.SimpleFormController.showForm(SimpleFormController.java:201)
   at org.springframework.web.servlet.mvc.SimpleFormController.showForm(SimpleFormController.java:178)
   at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:341)
   at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:281)
   at java.lang.Thread.run(Thread.java:722)
Caused by: java.sql.SQLException: java.lang.ArrayIndexOutOfBoundsException
   at org.hsqldb.jdbc.JDBCPreparedStatement.executeQuery(Unknown Source)
   ... 82 more
Caused by: org.hsqldb.HsqlException: java.lang.ArrayIndexOutOfBoundsException
   at org.hsqldb.result.Result.newErrorResult(Unknown Source)
   ... 86 more
Caused by: java.lang.ArrayIndexOutOfBoundsException
Edit: removed *, it was used because my first post detected "BoundsEx" as "sex" so flagged as spam, this however is no longer required.
w1ll14m
Re: Exception when an LDAP user tries to visit the "Admin Pa
Unread postby Madevil » 22 Dec 2016, 16:57
Try the following:
go to Settings > Reset > Reset Access Control
go to Settings > Reset > Cleanup Statistics
go to Settings > Reset > Cleanup History
go to Settings > Access (recheck security for LDAP group)
go to Settings > Media Tools > Normal Rescan
wait until scan is finished, restart the Madsonic service and try again.
http://beta.madsonic.org/pages/ldap.jsp#3
btw: ... also uploading new build with LDAP library update!
Has thanked: 1325 times
Been thanked: 963 times
Return to Bug Reports 6.x
