Captcha & Language
Captcha & Language
Unread postby nicodelux » 23 Dec 2016, 21:32
I've updates Madsonic to Server 6.2.9080 and there are a few bugs.
1- I still have the same captcha bug with user signup:
ERROR: Stoken expired ...
Need I do something to remove the bug ? Or maybe to disable the captcha ?
2- Language is still in english in the main menu bar. Just playlist is translated :)
If you need or want I can help you to translate in French & German
Have a good evening.
Re: Captcha & Language
Unread postby e1z0 » 24 Feb 2017, 15:23
On 6.2.9260 same thing with captcha.
Has thanked: 1 time
Unread postby TastyJams » 25 Feb 2017, 19:44
For the captcha issue, your system clock is out of sync with google which is causing the error.
On Ubuntu, I fixed the issue by running:
sudo ntpdate -s
sudo service madsonic restart
Happens every once in a while.
Has thanked: 2 times
Been thanked: 21 times
Return to Bug Reports 6.x
