Sonos Problems
Posted: 03 Jan 2017, 10:07
by michi
 VERSION:      MADSONIC 6.2 | BUILD: 9080
 SERVLET:      JETTY
 SERVER:       CPU: Intel Celeron J1900 | ARCH: X64 | MEMORY: 4GB | HDD: 6TB
 OS:           Ubuntu Server 16.04
 SYSTEM:       SERVER
 INSTALLER:    DEB
 JAVA:         OPEN JDK 1.8
 BROWSER:      CHROME 55
 CLIENT:       SONOS
 DESCRIPTION:  Can't skip to position in transcodet tracks, can't resume transcodet songs aufter pause, random album view is empty in the sonos app
 REPRODUCIBLE: YES
I didn't change transcoding settings.
Thanks in advance
Re: Sonos Problems
Posted: 03 Jan 2017, 16:07
This error has just been investigated with the Sonos Support, more information will follow.
Re: Sonos Problems
Posted: 03 Jan 2017, 16:10
by michi
Hey,
sounds good, Thanks!
Schöne Grüße aus Salzburg :D
Re: Sonos Problems
Posted: 03 Jan 2017, 16:35
by michi
Hey,
just a quick question: do you think this will get fixed? This is a dealbreaker for me, so i don't want to buy a license if it doesn't work.
But 99€ instead of 148€ would be pretty nice..
Re: Sonos Problems
Posted: 03 Jan 2017, 16:55
Yes, i hope so! :D
As workaround you can turn off transcoding for SONOS !
Settings > Player > Select your Sonos Player from Dropdown list > deselect audio->mp3 > Save
Now Sonos plays your files directly without transcoding (but will have some other issues with special audio formats)
Re: Sonos Problems
Posted: 03 Jan 2017, 17:46
by michi
Madevil wrote:Yes, i hope so! :D
Never thought of that, but it works! thanks!
Also my problem with the random album view kinda solved itself?
So i'm pretty happy for now :D
