[SOLVED] Error when hitting "Shared Media" in settings
Unread postby troycarpenter » 05 Jan 2017, 20:35
Got this when I hit "Shared Media" in settings. Version MADSONIC 6.2.9080.2a5cd1f.20161222.0601
Exception   java.lang.IllegalArgumentException
Message   No enum constant org.madsonic.domain.UrlRedirectType.false
Java version   Oracle Corporation 1.8.0_101
Operating system   Linux 4.4.35-1-pve
Server   jetty/8.y.z-SNAPSHOT
Memory   Used 137 of 318 MB
Stack trace   java.lang.IllegalArgumentException: No enum constant org.madsonic.domain.UrlRedirectType.false
   at java.lang.Enum.valueOf(Enum.java:238)
   at org.madsonic.domain.UrlRedirectType.valueOf(UrlRedirectType.java:1)
   at org.madsonic.service.SettingsService.getUrlRedirectType(SettingsService.java:1580)
   at org.madsonic.service.SettingsService.getUrlRedirectUrl(SettingsService.java:1565)
   at org.madsonic.service.ShareService.getShareBaseUrl(ShareService.java:119)
   at org.madsonic.controller.ShareSettingsController.handleRequestInternal(ShareSettingsController.java:81)
troycarpenter
Has thanked: 19 times
Been thanked: 50 times
Re: Error when hitting "Shared Media" in settings
Unread postby Madevil » 05 Jan 2017, 20:55
please go to Settings > Network
and configure the network section for your needs, save settings and try again.
Has thanked: 1338 times
Unread postby troycarpenter » 05 Jan 2017, 21:00
When I hit "network", I get the following:
 Error
Memory   Used 176 of 320 MB
   at org.madsonic.controller.NetworkSettingsController.formBackingObject(NetworkSettingsController.java:72)
   at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:361)
   at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:341)
   at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:281)
troycarpenter
Unread postby Madevil » 05 Jan 2017, 21:11
sounds like corrupted values in your config file.
please try:
  • stop madsonic service
  • rename the madsonic.properties file to madsonic.properties.backup
  • restart madsonic service
  • configure general & network settings again and click save
Unread postby troycarpenter » 05 Jan 2017, 21:56
Ok. Will try and let you know the result.
EDIT: That seems to have fixed the issue, and the web player issue at the same time. Now I have to reconfigure. Good thing a number of items are saved in the database, that would have been a pain to reconfigure given how many media folders I have...time to reconsider how I have them organized, I guess.
troycarpenter
Unread postby troycarpenter » 05 Jan 2017, 23:06
Followup question.
How do you tell what the shared media is without clicking on it? The description is blank by default.
troycarpenter
Return to Bug Reports 6.x
