Constant CPU Usage
Constant CPU Usage
Unread postby ThaRappa » 10 Jan 2017, 15:54
I've been running 6.2.9080 for a few weeks and I've notice that the madsonic-service.exe process is always running and chewing up between 15 and 50% of my CPU clock (according to Windows). Not sure if this is a bug, but on older builds this wasn't an issue. This issue persists through stopping and starting the service, as well as through a reboot. I've set Windows Defender to not scan the madsonic folder, but I'm still seeing high CPU usage. Is anybody else facing this in the new alpha or should I try to uninstall and reinstall?
Version MADSONIC 6.2.9080.2a5cd1f.20161222.0530 - IP address [192.168.1.100]
Server jetty/8.y.z-SNAPSHOT, java 1.8.0_101, Windows 10 10.0 (amd64) (190.8 MB / 472.0 MB)
Size: Database: 753MB, Thumbs-Cache: 72MB, LastFM-Cache: 52MB, Lucene-Cache: 10MB
Hardware:
Processor: Intel i3-2130 @3.4Ghz
Ram: 6 GB
ThaRappa
Has thanked: 2 times
Return to Bug Reports 6.x
