Podcast with unicode characters in XML do not work
Posted: 13 Feb 2017, 17:16
by troycarpenter
I have found another podcast that doesn't seem to work with the Madsonic podcatcher. The podcast in question has unicode characters in the XML which seem to cause parsing errors. I have confirmed this by downloading a copy of the XML file locally, removing the XML characters, and pointing Madsonic at the local copy of the XML. The podcast will then process and download as expected.
I will send you a URL to the feed in question.
Re: Podcast with unicode characters in XML do not work
Posted: 18 Feb 2017, 02:38
by huggenknubbel
Not only with Podcasts. i also get trouble with Music with Unicode Characters.
i have some Music with ä, ö, ü, "_" and so on. The ID3 Tag - Filescan doesnt list that in the Libary.
Posted: 20 Feb 2017, 00:39
by troycarpenter
huggenknubbel wrote:Not only with Podcasts. i also get trouble with Music with Unicode Characters.
Yes, I've seen that too with the scanner. I've had to watch the log file and fix any filenames so the scanner would catalog them.
