BPM stripping the bad characters
Unread postby Matt Zornig » 20 Feb 2017, 21:53
SERVER: jetty/8.y.z-SNAPSHOT, java 1.8.0_121, Linux 3.10.77 (amd64) (330.8 MB / 457.0 MB)
DESCRIPTION: see topic subject
REPRODUCIBLE: Yes.
Not much of a bug report, but some kind of feature request too.
While going through the serverlog, I saw a lot of those lines:
[2017-02-20 21:17:42,516] WARN JaudiotaggerParser - Error when parsing tags in /path/to/music/superdupermusicfile.mp3 For input string: "159 BPM"
java.lang.NumberFormatException: For input string: "159 BPM"
   at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2043)
   at sun.misc.FloatingDecimal.parseDouble(FloatingDecimal.java:110)
   at java.lang.Double.parseDouble(Double.java:538)
   at org.madsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:177)
   at org.madsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:48)
   at org.madsonic.service.MediaFileService.createMediaFile(MediaFileService.java:911)
   at org.madsonic.service.MediaFileService.updateChildren(MediaFileService.java:729)
   at org.madsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:330)
   at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:418)
   at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:422)
   at org.madsonic.service.MediaScannerService.doFolderScanLibrary(MediaScannerService.java:282)
   at org.madsonic.service.MediaScannerService.access$000(MediaScannerService.java:51)
   at org.madsonic.service.MediaScannerService$3.run(MediaScannerService.java:178)
Maybe its possible to strip all the alphabetical characters and leave only the numbers, when parsing the BPM tags?
That way, the log stays smaller, is easier to read and the BPM gets its way -hopefully correctly parsed- into the database.
Been thanked: 20 times
Re: BPM stripping the bad characters
Unread postby Madevil » 22 Feb 2017, 00:01
next snapshot build parse bpm values correctly if it contains "bpm" as string.
Has thanked: 1339 times
Unread postby Matt Zornig » 03 May 2018, 09:41
BROWSER: FF 53.x
REPRODUCIBLE: Yes
It does not work with this build.
[2018-05-03 10:08:55,841] WARN JaudiotaggerParser - Error when parsing tags in /volume1/Media/B/Big L/1994 - Lifestylez Ov Da Poor & Dangerous [TAPE+Ap]/110. Big L - Da Graveyard.mp3 For input string: "j"
java.lang.NumberFormatException: For input string: "j"
   at org.madsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:201)
   at org.madsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:50)
   at org.madsonic.service.MediaFileService.createMediaFile(MediaFileService.java:928)
   at org.madsonic.service.MediaFileService.updateChildren(MediaFileService.java:746)
   at org.madsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:333)
   at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:508)
   at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:512)
   at org.madsonic.service.MediaScannerService.doFullScanLibrary(MediaScannerService.java:361)
   at org.madsonic.service.MediaScannerService.access$200(MediaScannerService.java:62)
   at org.madsonic.service.MediaScannerService$4.run(MediaScannerService.java:209)
110. Big L - Da Graveyard.rar
The mp3 file. Password is my mailadress. Please delete after checking.
(7.36 MiB) Downloaded 22 times
Return to Bug Reports 6.x
