java: overhead limit exceeded (while playing)
Unread postby Matt Zornig » 11 Mar 2017, 02:11
BROWSER: FF 52.x
DESCRIPTION: music stopped. java exception thrown.
while listening to music.
suddenly, there was silence :-)
Error
Exception    org.springframework.dao.TransientDataAccessResourceException
Message    PreparedStatementCallback; SQL [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.data,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.mood,media_file.bpm,media_file.composer,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.first_scanned,media_file.children_last_updated,media_file.present,media_file.version,media_file.rank from media_file where present and type = ? and media_file.folder in (select path from music_folder where id in (select music_folder_id from user_group_access where user_group_id=? and enabled))ORDER BY first_scanned DESC limit ? offset ?]; java.lang.OutOfMemoryError: GC overhead limit exceeded; nested exception is java.sql.SQLException: java.lang.OutOfMemoryError: GC overhead limit exceeded
Java version    Oracle Corporation 1.8.0_121
Operating system    Linux 3.10.102
Server    jetty/8.y.z-SNAPSHOT
Memory    Used 41 of 388 MB
Stack trace    org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select media_file.id,media_file.path,media_file.folder,media_file.type,media_file.override,media_file.format,media_file.data,media_file.title,media_file.album,media_file.album_name,media_file.artist,media_file.album_artist,media_file.disc_number,media_file.track_number,media_file.year,media_file.genre,media_file.mood,media_file.bpm,media_file.composer,media_file.bit_rate,media_file.variable_bit_rate,media_file.duration_seconds,media_file.file_size,media_file.width,media_file.height,media_file.cover_art_path,media_file.parent_path,media_file.play_count,media_file.last_played,media_file.comment,media_file.created,media_file.changed,media_file.last_scanned,media_file.first_scanned,media_file.children_last_updated,media_file.present,media_file.version,media_file.rank from media_file where present and type = ? and media_file.folder in (select path from music_folder where id in (select music_folder_id from user_group_access where user_group_id=? and enabled))ORDER BY first_scanned DESC limit ? offset ?]; java.lang.OutOfMemoryError: GC overhead limit exceeded; nested exception is java.sql.SQLException: java.lang.OutOfMemoryError: GC overhead limit exceeded
   at org.madsonic.dao.AbstractDao.query(AbstractDao.java:107)
   at org.madsonic.dao.MediaFileDao.getHistory(MediaFileDao.java:983)
   at org.madsonic.controller.HistoryController.handleRequestInternal(HistoryController.java:92)
Caused by: java.sql.SQLException: java.lang.OutOfMemoryError: GC overhead limit exceeded
   at org.hsqldb.jdbc.JDBCPreparedStatement.executeQuery(Unknown Source)
   ... 76 more
Caused by: org.hsqldb.HsqlException: java.lang.OutOfMemoryError: GC overhead limit exceeded
   at org.hsqldb.result.Result.newErrorResult(Unknown Source)
   ... 80 more
Caused by: java.lang.OutOfMemoryError: GC overhead limit exceeded
complete log here
Has thanked: 21 times
Been thanked: 14 times
Return to Bug Reports 6.x
Users browsing this forum: Google [Bot] and 1 guest
