Madsonic fails to play next track in que
Unread postby magicd2 » 25 Apr 2017, 11:15
Hi i have a recurring issue with madsonic where it fails to load the next track and has to be quit and restarted in order to have it work again. Sometimes this barely happens other times it is every track. this is the message i get once quitting Madsonic
Thanks in advance
Exception    org.springframework.jdbc.CannotGetJdbcConnectionException
Message    Could not get JDBC Connection; nested exception is java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
Java version    Oracle Corporation 1.7.0_79
Operating system    Mac OS X 10.11.4
Server    jetty/8.y.z-SNAPSHOT
Memory    Used 149 of 260 MB
Stack trace    org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
   at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:575)
   at org.madsonic.dao.AbstractDao.query(AbstractDao.java:109)
   at org.madsonic.dao.AbstractDao.queryOne(AbstractDao.java:183)
   at org.madsonic.dao.UserDao.getUserSettings(UserDao.java:209)
   at org.madsonic.service.SettingsService.getUserSettings(SettingsService.java:2565)
   at org.madsonic.i18n.MadsonicLocaleResolver.doResolveLocale(MadsonicLocaleResolver.java:66)
   at org.madsonic.i18n.MadsonicLocaleResolver.resolveLocale(MadsonicLocaleResolver.java:54)
   at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1190)
   at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1001)
   at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:945)
   at org.madsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:49)
Caused by: java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
   at org.hsqldb.jdbc.JDBCConnection.(Unknown Source)
   at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
   at org.hsqldb.jdbc.JDBCDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(DriverManager.java:571)
   at java.sql.DriverManager.getConnection(DriverManager.java:187)
   at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:173)
   at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:164)
   at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:153)
   at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119)
   at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
   at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
   ... 82 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
   at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
   at org.hsqldb.DatabaseManager.newSession(Unknown Source)
   ... 93 more
magicd2
Has thanked: 2 times
Return to Bug Reports 6.x
