Playlists won't import
Unread postby thechez » 11 Jun 2017, 16:26
Does anyone else have trouble after a full rebuild with trying to reimport playlists as it doesn't update automatically?
The ones that are updating from the scan in the appropriate folders have no files and when I try to import any of my older playlists it doesn't import. This has been happening since version 6 came along. I've just started editing the mood tags in Kid3 instead of relying on playlists.
thechez
Has thanked: 1 time
Been thanked: 8 times
Re: Playlists won't import
Unread postby Madevil » 11 Jun 2017, 18:53
If the backup playlist-path is set correctly before the full scan is started,
you should be able to recovery all playlist afterwards.
Settings > Playlists > Recover Playlists
Has thanked: 1339 times
Return to Bug Reports 6.x
