DSM6: no search possible after re-install (No matches found)
Posted: 20 May 2018, 03:24
REPRODUCIBLE: YES!
I had to re-install the Madsonic Package, so I
deinstalled it via the package manager, and
removed all files in /volume1/public/Madsonic
(I can see /var/packages/Madsonic is removed after deinstallation, so I think, nothing is left from the madsonic install...?)
After the initial scan of my media folders had finished,
I tried a simple search, but nothing is found. ever. no matter what searchterm I use.
All music is avaiable, say, via HOME -> RECENTLY ADDED or RANDOM. I can play music fine.
But no searchterm gives any output, besides "No matches found."
No Log, because nothing is written to the log when I enter a search...
EDIT:
If I use the Database Tool, like
SELECT * FROM album
SELECT * FROM artist
