DSM6: Madsonic not working after re-install (No WebGUI)
Unread postby Matt Zornig » 20 May 2018, 22:07
REPRODUCIBLE: YES. Only first and fresh install worked correctly.
Madsonic is not working anymore after a re-install.
After deinstalling the package via the Package Manager, I removed those files, I found on the NAS and restarted the NAS.
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/cgroup.clone_children
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/cgroup.event_control
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/cgroup.procs
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/cpuacct.stat
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/cpuacct.usage
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/cpuacct.usage_percpu
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/notify_on_release
/sys/fs/cgroup/cpuacct/pkgctl-Madsonic/tasks
/sys/fs/cgroup/memory/pkgctl-Madsonic
/sys/fs/cgroup/memory/pkgctl-Madsonic/cgroup.clone_children
/sys/fs/cgroup/memory/pkgctl-Madsonic/cgroup.event_control
/sys/fs/cgroup/memory/pkgctl-Madsonic/cgroup.procs
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.failcnt
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.force_empty
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.limit_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.max_usage_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.memsw.failcnt
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.memsw.limit_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.memsw.max_usage_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.memsw.usage_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.move_charge_at_immigrate
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.oom_control
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.pressure_level
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.soft_limit_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.stat
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.swappiness
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.usage_in_bytes
/sys/fs/cgroup/memory/pkgctl-Madsonic/memory.use_hierarchy
/sys/fs/cgroup/memory/pkgctl-Madsonic/notify_on_release
/sys/fs/cgroup/memory/pkgctl-Madsonic/tasks
/usr/syno/etc/packages/Madsonic
/var/log/upstart/pkgctl-Madsonic.log
/tmp/hsperfdata_madsonic
I then installed the Madsonic Package with no restore.
It worked well, but unfortunately, I get a
HTTP ERROR: 503
Problem accessing /. Reason:
    Service Unavailable
When I try to open http://mynas:4040/ via FireFox Browser.
This is the madsonic_sh.log
https://pastebin.com/zhhK1u24
This is the madsonic-debug.log
https://pastebin.com/qcu2EA9J
This is the madsonic_package.log
https://pastebin.com/zEsGA44y
This is the madsonic.log
https://pastebin.com/JqcqZ4RV
All from the /var/packages/Madsonic/target/ dir.
(Unfortunately, the package install log is removed shortly after the install finishes, so I cannot upload it.)
Been thanked: 20 times
Return to Bug Reports 6.x
