disable "Artist Hub" in the settings too
Unread postby Matt Zornig » 13 Mar 2017, 01:18
BROWSER: FF 52.x
Since it takes about 3 minutes to show artists for the letter Q, I assume it takes pretty much longer for the letters E or T or any other.
So we try to never use any features of madsonic, which will generate an index or something which takes more than 20 seconds. (since it kills madsonic or java on our system very often on long sql statements)
Therefore, I'd like to DISABLE the
Artist Hub
the same way, I've disabled
All Artists
as an admin,
but it seems not possible right now.
only 3 minutes in the log, but ages for the user....
[2017-03-13 01:01:58,217] DEBUG MediaScannerService - WATCHDOG:SCHEDULE: 2017-03-13 01:45:00.0 [testing]
[2017-03-13 01:01:58,217] INFO MediaScannerService - Automatic media scanning disabled.
[2017-03-13 01:02:02,336] DEBUG LastFMService - ## ArtistAutoCorrect: ? -> [unknown]
[2017-03-13 01:02:40,517] DEBUG AbstractDao - fn::getArtistFolder::getArtistsForFolder:  9712 ms:  select distinct lower(name) from artist where lower(name)=? or lower(artist_folder)=? and song_count > 1
[2017-03-13 01:03:39,990] DEBUG AbstractDao - fn::getAlbumsForArtist::getAlbumsForArtist:  59472 ms:  select id, path, name, nameid3, SetName, artist, albumartist, song_count, duration_seconds, cover_art_path, play_count, last_played, comment, created, last_scanned, present, mediaFileId, genre, year from album where lower(artist)=? and present order by year desc
[2017-03-13 01:03:44,995] DEBUG AbstractDao - fn::getAlbumsForArtist::getAlbumsForArtist:  3853 ms:  select id, path, name, nameid3, SetName, artist, albumartist, song_count, duration_seconds, cover_art_path, play_count, last_played, comment, created, last_scanned, present, mediaFileId, genre, year from album where lower(artist)=? and present order by year desc
[2017-03-13 01:05:50,790] DEBUG LastFMService - ## ArtistAutoCorrect: Q -> Q
Been thanked: 19 times
Wording can be improved for optical recognition 8-)
Unread postby Matt Zornig » 13 Mar 2017, 04:44
...found it...
can we please have a indentical wording within madsonic, which makes visual matching (aka reading) possible ;-)
RED words are taken from the left navigation frame. Unfortunately, they differ at the moment, so its not easy for non-native-speakers of english to identify corresponding menu-items.
Re: disable "Artist Hub" in the settings too
Unread postby Matt Zornig » 13 Mar 2017, 04:49
also,
this wording is confusing.
should "user level" be "user group" ?
or is there a special level-thing. if so, what is is?
