Keep SSL Certificates and Settings on Update
Posted: 20 Oct 2017, 12:38
by KaeTuuN
Well... The Title says it all.
It would be great, if you don't loose the SSL settings made in madsonic.sh on every update!
Greetings
Kae
Re: Keep SSL Certificates and Settings on Update
Posted: 22 Oct 2017, 16:40
by mplogas
Regarding SSL Certs, I patched the madsonic.sh file. The only thing I need to do on every update is running a diff between the provided madsonic.sh and mine (and enhance mine accordingly).
Now, how did I do that:
Create a JKS and put your key in it. Remember the password, for obvious reasons. It should have a single alias:
root@media:/usr/home/marc # keytool -list -keystore /usr/local/madsonic/madsonic.jks
Enter keystore password:
Keystore type: JKS
Keystore provider: SUN
Your keystore contains 1 entry
madsonic, May 2, 2017, PrivateKeyEntry,
Certificate fingerprint (SHA1): omitted
Refer to this handy cheat sheet for common Java keytool commands
Now, add two more variables to the shell script:
MADSONIC_DEFAULT_KEYSTORE_PASSWORD=password
MADSONIC_DEFAULT_KEYSTORE=/usr/local/madsonic/madsonic.jks
Next, add both things to the parse arguments part, in case you'd like to provide the keystore and password via commandline. Also, enhance the help output accordingly. However, this is optional.
the following step is mandatory, and the important one. Look for following line
${JAVA} -Xms${MADSONIC_INIT_MEMORY}m -Xmx${MADSONIC_MAX_MEMORY}m \
below that line, you can find a couple of JVM arguments, that are provided to the runtime when the WAR starts. Add the following two lines
 -Dmadsonic.ssl.keystore=${MADSONIC_DEFAULT_KEYSTORE} \
 -Dmadsonic.ssl.password=${MADSONIC_DEFAULT_KEYSTORE_PASSWORD} \
That's it. this will keep your certs in the JKS you provided. You should also use this approach if you want to use a valid cert.
(Maybe @madsonic can add this patch to the next release)
Hth,
Marc
