Madsonic: security risk?
Madsonic Server 6.x
Unread postby zzzonedotnet » 30 Jul 2017, 20:01
Does leaving ports open for Madsonic produce a significant security risk?
I'm sorry if this question may have been asked before.
Thanks for your consideration and answers.
Z.N
zzzonedotnet
Has thanked: 5 times
Been thanked: 8 times
Re: Madsonic: security risk?
Unread postby zzzonedotnet » 05 Aug 2017, 15:47
Here's something I found on the subject elsewhere:
"While opening ports does put you more at risk than having none open, you are only in danger if an attack can exploit the service that is using that port. A port is not an all access pass to your PC/network if an attacker happens upon it. They would need to manipulate whatever it is on the other side to gain some type of basic system access, then they could 'maybe' gain enough privileges to compromise your system. It's a bit like leaving your car keys in a bathroom 100 miles away. While someone could use them to steal your car, they still have a loooong way to go to make it happen.
As you said, companies around the world have ports open so they can do business. Another fact is that whatever those companies are doing is probably a lot more interesting to attackers than the family photos and Bejeweled Blitz your dad has on his PC.
You also need to consider just because you open ports on the router does not mean you opened ports on the PC firewalls. If you open port 3333 on your router, chances are it is still blocked by your PCs firewall, so you in still protected. Typically, you open the ports you need on the router, and open the ports on ONLY the PC firewall that needs access through them.
Finally, depending on what services you are planning on using, they may be uPnP compatible. In that case, they will open the ports they need when in use, and close them automatically when they aren't. You said you have a random 5-digit port opened right now, and have been using it. Why not stick with it then? There is nothing to be gained by using the "standard" ports unless you need to."
zzzonedotnet
Return to Server 6.x
