Not working in Kubuntu 18.04
Posted: 05 May 2018, 18:07
by Eddie
This was running perfectly in Ubuntu 16.04
I did a nuke and pave and installed Kubuntu 18.04 and ran the following commands after downloading 20180107_madsonic-6.3.9840.deb
sudo apt-get install openjdk-8-jre -y
sudo dpkg -i ~/Downloads/20180107_madsonic-6.3.9840.deb
When i try to access madsonic via localip:4040 via a chrome browser from a local computer inside my network i get the following
HTTP ERROR: 503
Problem accessing /. Reason:
Service Unavailable
Here is my output from /var/madsonic/madsonic_sh.log
root@server:/var/madsonic# cat madsonic_sh.log
May 05, 2018 2:30:21 PM org.springframework.context.support.ClassPathXmlApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@5b87ed94: startup date [Sat May 05 14:30:21 EDT 2018]; root of context hierarchy
May 05, 2018 2:30:21 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
May 05, 2018 2:30:21 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@4988d8b8: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
No newer update found.
Extracting webapp to /var/madsonic/jetty/9840
2018-05-05 14:30:21.981:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2018-05-05 14:30:24.516:INFO:/:Initializing Spring root WebApplicationContext
[2018-05-05 14:30:25] [ERROR] [main] ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]; nested exception is org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:413)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:335)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:303)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:174)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:209)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:180)
        at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:125)
        at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:94)
        at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
        at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:545)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:454)
        at org.madsonic.booter.deployer.MadsonicDeployer.deployWebApp(MadsonicDeployer.java:247)
        at org.madsonic.booter.deployer.MadsonicDeployer.<init>(MadsonicDeployer.java:102)
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
        at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:488)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:638)
        at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:942)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:482)
        at org.madsonic.booter.Main.<init>(Main.java:46)
        at org.madsonic.booter.Main.main(Main.java:85)
Caused by: org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
        at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:139)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1427)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1422)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:187)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.doRegisterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:147)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:101)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:495)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:391)
        ... 47 common frames omitted
Caused by: java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
        at org.apache.cxf.jaxws.spring.NamespaceHandler.init(NamespaceHandler.java:34)
        at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:130)
        ... 54 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException
        at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:466)
        at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
        at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
        ... 56 common frames omitted
2018-05-05 14:30:25.280:WARN:oejw.WebAppContext:Failed startup of context o.e.j.w.WebAppContext{/,file:/var/madsonic/jetty/9840/webapp/},madsonic.war
Caused by:
Caused by:
Caused by:
2018-05-05 14:30:25.315:INFO:oejs.AbstractConnector:Started @0.0.0.0:4040
May 05, 2018 2:30:25 PM org.springframework.remoting.rmi.RmiServiceExporter getRegistry
May 05, 2018 2:30:25 PM org.springframework.remoting.rmi.RmiServiceExporter prepare
INFO: Binding service 'MadsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
Thanks in Advance
Re: Not working in Kubuntu 18.04
Posted: 06 May 2018, 03:45
by Eddie
Well i deleted madsonic and java and tried again with a different java and now it works
sudo apt remove madsonic
sudo apt remove openjdk-8-jre
I did the following
sudo add-apt-repository ppa:webupd8team/java
sudo apt update
sudo apt install oracle-java8-installer
sudo apt install oracle-java8-set-default
It seems to be working now
May 05, 2018 10:39:25 PM org.springframework.context.support.ClassPathXmlApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@cc34f4d: startup date [Sat May 05 22:39:25 EDT 2018]; root of context hierarchy
May 05, 2018 10:39:25 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
May 05, 2018 10:39:25 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@7a0ac6e3: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
2018-05-05 22:39:25.943:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2018-05-05 22:39:28.782:INFO:/:Initializing Spring root WebApplicationContext
[2018-05-05 22:39:30] [INFO ] [main] Version - HV000001: Hibernate Validator 5.2.4.Final
[2018-05-05 22:39:32] [INFO ] [main] CacheManager - The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
2018-05-05 22:39:36.554:INFO:/:Initializing Spring FrameworkServlet 'madsonic'
2018-05-05 22:39:38.338:INFO:oejs.AbstractConnector:Started @0.0.0.0:4040
[2018-05-05 22:39:52] [INFO ] [qtp1547425104-33] startup - Starting: DwrServlet v3.0.3-dev on jetty/8.y.z-SNAPSHOT / JDK 1.8.0_171 from Oracle Corporation at
Any idea why madsonic doesnt work anymore with this java
