Server 6.3.9840 DLNA enabled but does not open in Rhythmbox
Unread postPosted: 09 Aug 2018, 09:34
by chrissi55
I've Rhythmbox 3.4 installed with grilo-plugin 0.2 enabled
Under Rhythmbox i can see an entry for my DLNA Server but when klicking on it no subdirs / folders appear?
I've tried to uninstall rhythmbox + grilo and re-installed it - same result.
My AVM Fritz!Box Mediaserver ist reachable as expected.
What might be the mistake in my Madsonic Config?
In my user access level config i allowed guests so that a UPnP / DLNA Client could connect to my madsonic server.
:cry:
Re: Server 6.3.9840 DLNA enabled but does not open in Rhythm
Unread postPosted: 09 Aug 2018, 13:28
by chrissi55
...and same problem when using djmount 0.71
tested with
apt-get install djmount
mkdir ~/dlna
djmount ~/dlna
I see a folder named "Madsonic" as i configured under madsonic server WebUI
But opening this folder -> seeing it empty
So what could be wrong with my madsonic installation??
Unread postPosted: 12 Aug 2018, 11:01
by chrissi55
So can't get Rhythmbox to work with madsonic DLNA Server i decided to switch over to Clementine
With Clementine's build in support for subsonic i was able to log in to my madsonic server - beneath upnp.
So if someone will find another solution with grilo-plugins enabled - please tell me.
