Madsonic 5.0.3780 server
Android client 5.4
"connection failure. wrong username or password"
Ever since upgrade, been getting this error from the madsonic app. I delete and recreate the profile and this works for awhile but next scan and I get same error.. help please...
gihub.madmarty.madso.parser.SubsonicRESTException:
- Been thanked: 3 times
- Attachments
- madsonic.log
- (130.82 KiB) Downloaded 191 times
- These users thanked the author ramapoughnative for the post:
Re: gihub.madmarty.madso.parser.SubsonicRESTException:
Seems the madsonic app was corrupted. I reloaded app and all is ok again.. the corruption was sending wrong username and password info to the server.
Nope I was wrong.. it's failed again.. why do I keep getting this error and have to rebuild the user Getting this error in the log..
"RESTRequestParameterProcessingFilter Authentication failed for user dad"
Server is on dual core windoze 8.1
Bump... hello? Am I the only person getting this?
Do you get this error only on the client or on the Web Interface too ?
Which Android version/rom did you use?
Did you complete delete cache / uninstall ?
you can try to delete this folder too if exist for full cleanup
... then reinstall the android client.
Attention: password is case sensitive
/<SDCARD>/madsonic/
/data/data/github.madmarty.madsonic/
