Madsonic Server 5.0 Tomahawk Resolver
Unread postby Madevil » 02 Dec 2013, 22:44
Madsonic 5.xTomahawk Player Plugin
http://www.tomahawk-player.org/
Contribution: https://github.com/tomahawk-player/toma ... ic/content developed by tomahawk
Current release v0.0.1:
INSTALLATION
1. extract resolver plugin to %USERPROFILE%\AppData\Local\Tomahawk\atticaresolvers
2. install from file Settings -> Configure Tomahawk ... -> Services -> Install from File
3. Select from %USERPROFILE%\AppData\Local\Tomahawk\atticaresolvers\madsonic\contents\code the resolver -> madsonic.js
2. configure resolver with your username, password and your Serverurl example http://yourserver.com:8080
3. Fully rescan Collections
Done ! :D
DOWNLOAD
madsonic-resolver-0.0.1.zip
(183.34 KiB) Downloaded 177 times
Has thanked: 1339 times
Re: Madsonic Server 5.0 Tomahawk Resolver
Unread postby skopo » 03 Dec 2013, 12:51
Does this work on OSX?
skopo
Has thanked: 11 times
Been thanked: 20 times
Unread postby wpjonesnh » 03 Dec 2013, 14:39
Downloaded and added to to C:\Users\<username>\AppData\Local\Tomahawk\atticaresolvers on Windows 8.1 pro. Restarted Tomahwak but it still does not see the plugin.
Regards,
-wpjonesnh
Edit: I compared the directory contents with another plugin and noticed that the metadata.desktop file is not being created when restarting the application but I am not sure if it's created by the app or some other source.
wpjonesnh
Has thanked: 2 times
Unread postby tomdj » 03 Dec 2013, 15:52
Thank you very much Madevil, it works perfect now :) .
I didn´t install your resolver so how you wrote, but simple, with install option in the setting gui -> Configure Tomahawk/Services/Install from File .... madsonic.js file.
tomdj
Unread postby wpjonesnh » 03 Dec 2013, 16:15
I'm in business! Thanks to tomdj for his post which added the missing piece and Madevil for an awesome music streamer for "testing". ;)
wpjonesnh
Unread postby Madevil » 03 Dec 2013, 18:21
Thanks tomdj for the missing link!
i add this to the description.
Unread postby Madevil » 03 Dec 2013, 18:47
skopo wrote:Does this work on OSX?
Sure, this is independent from the os
Unread postby tomdj » 03 Dec 2013, 19:14
I am not shure about the extraction of resolver. I´ll test the installation of the madsonic´s resolver on my linux, too.
I think, that you can extract the resolver, where you want, the install script (madsonic.js) does all needed changes for tomahawk. I did only download the resolver to my documents directory, unziped and installed in tomahawk over "Service" menu.
tomdj
Unread postby tomdj » 03 Dec 2013, 20:35
I have tested now; it works, but if you remove or rename this madsonic resolver folder, the resolver doesn´t work. Madevil wrote the perfect installation about his resolver, so the resolver is forever secured in user´s profile :).
tomdj
Unread postby triptol » 18 Feb 2014, 12:10
Would it be possible to make it work with HTTPS? Had a quick look at the source, see that various changes are required, more than I am able to implement.
triptol
Has thanked: 6 times
Been thanked: 8 times
Unread postby tomdj » 22 Aug 2014, 14:47
I have noticed, that the Tomahawk resolver does work in 5.1 public preview on new 0.8 Tomahawk (nightly build), but the Madsonic server isn´t present in the navigation menu on left side. I can only search for artist, but i can´t browse server. How can i fix it, please ?
http://14all-all41.net/wp-content/uploads/2014/08/tomahawk-08.jpg
tomdj
Unread postby tomdj » 09 Nov 2014, 14:18
Tomahawk-player 0.8 final was released yesterday. Madsonic resolver works fine, but in the navigations menu is the entry (icon) still not present. It isn´t possible to browse files on the server. Please help.
tomdj
Return to Tomahawk
