Madsonic 5.x XBMC Plugin
http://xbmc.org/
0.5.2:
  • Update for Build 5060
  • Update Json Lib
0.5.1:
  • Update for Build 3800: add last played songs, new added songs
0.5.0:
  • browser by folder or artist
  • browse and play all your music/videos
  • browse starred artists, albums, songs
  • play at full quality (original files) or transcode to the bitrate of your choice in settings (full quality currently require DVDPlayer)
  • search for artist, album and songs
  • view hot, tip, newest, top rated, most played,recently played and random albums
  • generate random playlists by range of years and/or genre
  • play playlists from madsonic server
<playercorefactory>
    <rules action="prepend">
    </rules>
</playercorefactory>
Download
plugin.audio.madsonic.0.5.2.zip
(236.58 KiB) Downloaded 472 times
plugin.video.madsonic.0.5.2.zip
(236.56 KiB) Downloaded 348 times
plugin.audio.madsonic.0.5.1.zip
(225.92 KiB) Downloaded 492 times
plugin.video.madsonic.0.5.1.zip
(225.89 KiB) Downloaded 377 times
plugin.audio.madsonic.0.5.0.zip
(108.14 KiB) Downloaded 381 times
plugin.video.madsonic.0.5.0.zip
(108.12 KiB) Downloaded 358 times
Screenshot
Image Image Image Image
These users thanked the author Madsonic for the post (total 4):
chaliFabValjakscorZn
Rating: 30.77%
chali
Has thanked: 18 times
Been thanked: 35 times
Unread post by chali »
works nice=) movies looks so much better on the computer now =)
but like to have "latest added" if its possible
Thank You!!
/regards chali
chali wrote:Hi
Thank You!!
/regards chali
great if all work! :D
Do you see the "Newest" Section?
skopo
Has thanked: 8 times
Been thanked: 16 times
Unread post by skopo »
Works like a charm!
These users thanked the author skopo for the post:
tycoonbob
Unread post by tycoonbob »
I'm so excited to try this tonight!
These users thanked the author tycoonbob for the post:
skopo
Only minus so far is that when using music option and newest album section there is also all new video files...
mlutzow
Has thanked: 10 times
Unread post by mlutzow »
I have a beginner question about this plug-in, will it work on a 64 bit WIndows 7 install. I have some google TV's setup around the house and accessing the videos can be done but it is difficult to locate what I'm looking for.
Any help or recommendations on how to set this up and get it working would be extremely helpful.
Right now I have a DLNA renderer setup on the Google TV's and they recognize the Madsonic DLNA server but Madsonic deiivery gives me one long list of over 75,000 files...very difficult.
I can also see Windows Media player but that has drawbacks that make it a very poor option.
Thank you in advance.
Mark
xefil
Has thanked: 3 times
Unread post by xefil »
Working well, great! It's possible to include Pandora feature into this plugin?
Thank's, Simon
Tamps
Unread post by Tamps »
Realy strange thing has hapened. I dont see any arist names in xbmc anymore. I only see album/vinyl name and thats it. if I go to that folder then I only see track name. when I start the song then I can see arist/dj name. this is really annoying because I have about 420gb music in my computer. PS I use Index folder to play my track, because in the years I have come up whit my own solution to sort my music.
skopo
I just got same problem when I installed another computer with XBMC and Madsonic.
Haven't changed anything in the server end.
zeb
Unread post by zeb »
brilliant and works well, can I ask for a few tweaks using it for video by the way? when in any of the icon or fanart views what file is it looking for for the images or does it even look for images?
my folder structure is
Show
S01
Showname - Sxxexx - Episode Title
and every folder and subfolder has
but no images show up?
and also can we have an option to show the history section of madsonic please, so then we can see each individual episode thats been added new
I was going to use Raspbmc and the plex addon but think this is a much better way as its a lot lighter in size and function
Tamps
Tamps wrote:Realy strange thing has hapened. I dont see any arist names in xbmc anymore. I only see album/vinyl name and thats it. if I go to that folder then I only see track name. when I start the song then I can see arist/dj name. this is really annoying because I have about 420gb music in my computer. PS I use Index folder to play my track, because in the years I have come up whit my own solution to sort my music.
Problem still exists. its realy annoying. any way to fix this?`I installed also subsonic xbmc plugin and have the same problem.
rwllr
Unread post by rwllr »
Has anyone tried installing it on the iOS version? I get a 'script failed' error which I didn't get when trying it with XBMC on Android.
This error does come when I try other subsonic plugins too...I haven't tried other random plugins to see if they get that too.
Build 0.5.1:
xefil
Tamps
Can you fix this bug plz, this is really annoying for now cant see now artist name. only album/ep name and thats all and also for the tracknames, the same thing. how can I fix this bug???
Tamps
I dont get it, I first sayed about this bug in november. now its february and still developer havent answered to this question but STILL he is active in the forum!
I hope you will fix this the most annoyng bug!!
mlutzow
Finally installed Linux and installed this plug-in and all I can say is, very, very nice.
These users thanked the author mlutzow for the post:
EvylRat
Unread post by EvylRat »
I can't get this plug in to connect, it just times out.
skopo
With Gotham I'm having problems with playback. I can play only one song. When the next song cames playback stops...
Plus last.fm scrobbling isn't working.
baggar11
Unread post by baggar11 »
Yeah, I just noticed this too.
skopo wrote:With Gotham I'm having problems with playback. I can play only one song. When the next song cames playback stops...
