Madsonic Server 5.x Synology-DSM 5.x NAS Plugin
Unread postby Madevil » 16 Jan 2014, 18:28
Madsonic 5.x Synology-NAS PLugin
http://www.synology.com/
tested with
DSM 5.0-4418, DSM 4.3.3810
This beta package needs this requirements installed:
  • Perl
  • Java Manager
  • Serviio (ffmpeg)
Download
Madsonic5.1-B5060-016.spk
Madsonic5.0-B3860-012.spk
JavaSE: http://pcloadletter.co.uk/2011/08/23/ja ... -synology/
ffmpeg: http://pcloadletter.co.uk/2012/01/25/se ... o-package/
Has thanked: 1339 times
Re: Madsonic Server 5.0 Synology-NAS Plugin
Unread postby olive069 » 16 Jan 2014, 21:08
Very good news!!!!
It will be compatible with all ARM CPU models?
olive069
Has thanked: 9 times
Been thanked: 10 times
Unread postby muiz » 23 Jan 2014, 08:15
Awesome
muiz
Has thanked: 4 times
Unread postby Siutsch » 23 Jan 2014, 11:41
Can't wait ... ;)
Siutsch
Has thanked: 2 times
Unread postby olive069 » 03 Feb 2014, 13:24
Any progress? Even an alpha version?
olive069
Unread postby Siutsch » 28 Feb 2014, 07:54
Long time no news here ...
Can you perhaps say, from when to expect a release?
I am very excited ... :)
Siutsch.
Siutsch
Unread postby MuadDib_II » 11 Mar 2014, 11:29
Very good news !!!! :P
I was "forced" to return to Subsonic because there was no Madsonic package available for my NAS, now I'm glad to see that I will be able to use Madsonic once again :D
Can't wait :twisted:
MuadDib_II
Has thanked: 1 time
Unread postby olive069 » 17 Mar 2014, 12:46
penumbra wrote:I can`t wait.....
If there is any way to test a beta version - i would be glad !
I'm ready to test and give review too!
olive069
Unread postby olive069 » 28 Mar 2014, 21:54
Come on Madevil, bring the magic!
olive069
Unread postby Madevil » 28 Mar 2014, 22:08
olive069 wrote:Come on Madevil, bring the magic!
sorry for the long delay, i'am allready working on the new 5.1 branch,
at the moment i havn't much time to test every hardware type.
meanwhile i can release the old Madsonic 5.0 branch version. :D
Unread postby olive069 » 29 Mar 2014, 00:06
It's rolling!!
No issue until then.
olive069
Unread postby hanshans » 29 Mar 2014, 11:36
What about disk hibernation. Does it stay in hibernation until Its connected ?. If it does, i move it from my server to diskstation 412+
hanshans
Has thanked: 7 times
Unread postby olive069 » 29 Mar 2014, 17:29
stertje wrote:where do i finde java and servilo pakages
Add this repo to the package center (options) : http://packages.synocommunity.com
olive069
Unread postby olive069 » 31 Mar 2014, 22:23
On my Ds112, i notice some lags especially with large covers and instabillity with transcoding (ffmpeg).
olive069
Unread postby Siutsch » 02 Apr 2014, 20:20
After automatic Perl Update at DSM I get this:
HTTP ERROR: 503
Service Unavailable
Powered by Jetty://
I reinstalled, but same problem.
Siutsch
Unread postby olive069 » 07 Apr 2014, 11:57
After a few days using Madsonic 5.0 on my Syno DS112 runing on DSM 5.0.
- better use last java SE ver 8 : better disk & RAM usage.
- transcoding works well
- i found that tag reading is worse than subsonic : some of my albums have no tags at all.
- nice interface, smooth and slick!!
Thanks Mad for releasing it and i'm looking for 5.1 update!
olive069
Unread postby olive069 » 07 Apr 2014, 14:08
lionelkw wrote:Do you have some special setup for making transcoding work? Apart from installing Serviio.
No just copy the ffmpeg binary from serviio folder, chmod 655 and usual command line in Madsonic transcoding options. I only use Madsonic for audio files.
olive069
Unread postby HolgerWill » 10 Apr 2014, 08:31
Can somebody please describe how to copy ffmpeg from serviio folder.
Step by step ??
HolgerWill
Unread postby HolgerWill » 10 Apr 2014, 08:55
Now i have the following file in the following folders.
But transcoding still doesn`t work:
-rwxrwxrwx 1 root root 153616 Apr 10 07:47 ffmpeg
/usr/syno/synoman/webman/3rdparty/Madsonic/transcode
/volume1/@appstore/Madsonic/transcode
my downsample command is:
ffmpeg -i %s -ab %bk -v 0 -f mp3 -
HolgerWill
Unread postby olive069 » 10 Apr 2014, 09:54
Cn you post your madsonic log when you attempt to transcode a file?
olive069
Next
Return to Synology
