Madsonic Newsletter 02/2014
Unread postby Madevil » 11 Feb 2014, 23:28
Hi Madsonic Community!
Well i'm back again, after some weeks long busy at work. :roll:
I'll look through the support forum and hopefully can clarify many things.
but I have also good news which have occurred more in the background.
new 5.0 Build 3860
merged many subsonic 4.9 bug-fixes and improvements
new 5.1 Development Branch started
the new build is already being processed.
5.1 development goals
  • merge Last.FM API to main project, better integration with cache location (NAS)
  • extend Last.FM API Calls and DB (getTopTrack, get/setLovedTracks, getCharts, getAlbumImage, metaData, ...)
  • expand Pandora API to Clients and user profiles
  • extend REST API to Clients - more Metadata exchange
  • increase transcoding compatibility (support avconv, mencoder, ogg, subtitle, ...)
  • extend security groups (max audio/video transcoding settings)
  • extend video capabilities (metadata, visualization, transcoding)
  • Upgrade JWPlayer to http://mediaelementjs.com
  • new user-controllable "mediatag" system
  • new user-controllable Playbutton system
  • streamline interface
  • many more
Madsonic Client Google Store
all issues are cleared and the Madsonic app is back online on the Google Play Store
Madsonic Client improvements
many improvements will follow the first beta of the 5.1 server build
new Madsonic "Node" design phase started
more details about this new project will be published later.
Update UnRAID x86 Plugin
Update to newest Bugfix release 3860
new unRAID x64 Plugin
Create new Plugin for the unRAID 6.0 beta3 (x64) version
new Synology Plugin
Create new Plugin for the Synology NAS Series
maybe QNAP Plugin
Best Regards,
Reason: Update Infos
Has thanked: 1339 times
Re: Madsonic Newsletter 02/2014
Unread postby daneren2005 » 12 Feb 2014, 03:28
Looking forward to more client APIs! Have you had time to document what public APIs you have added so far?
Sent from my HTC One X using Tapatalk
daneren2005
Developer
Developer
Has thanked: 2 times
Been thanked: 11 times
Unread postby gurutech » 12 Feb 2014, 06:11
You may already have these listed under "many more", but I would like to see:
[*]Lyrics feature needs to be improved, as it fails to identify the correct song many times.
[*]20-second countdown timer for lyrics search (or eliminate the wait requirement)
[*]Integrated registration engine (with facebook and/or google + )
[*]The ability to "sync" playlists between "players" used by the same person (ie. if I am listening on my computer, have the ability to continue on my mobile device where the PC playlist was stopped/paused.)
[*]Ability to stay logged in "forever", and not automatically logout after a day or so.
Has thanked: 12 times
Been thanked: 131 times
Unread postby xefil » 17 Feb 2014, 10:19
Great to read you're working on 5.1 :)
If you need some beta testers, I'm glad to help you!
On the roadmap, If you could do someting for playlists it would be great... as written in your thread:
viewtopic.php?f=4&t=579#p2860
Cheers,
Simon
xefil
Has thanked: 5 times
Been thanked: 10 times
Unread postby chali » 18 Feb 2014, 02:56
I know a feature I miss, being able to choose between movies and music in a clear way
found in eg plex media server.
for example, one could choose to have two clear buttons which the user can choose between music or movie and series, or why not that one can choose from music, film, comics, just for kids movies, etc. admin would able to mark the folders to which they belong.
I also see a feature where you can choose which folders users can download, for example, I want my users to be able download their music playlists to ther mobiles, but I do not want them to be able to download movies.
function of selecting music or movies, nearly already exists but is unclear for an untrained user when he must select the folder itself in a drop-down window.
sincerely / Chali
chali
Has thanked: 89 times
Been thanked: 66 times
Unread postby vviudez » 25 Feb 2014, 19:57
Good news!!!
Any link to download the new build?
Need betatesters? ;-P
And .... there's any way that when I add a new video/audio to an existing folder, it appears in "Recently Added" page?
vviudez
Unread postby GJ51 » 25 Feb 2014, 22:30
GJ51
Has thanked: 68 times
Been thanked: 106 times
Unread postby vviudez » 25 Feb 2014, 23:30
I mean the download of the 3860 build...
vviudez
Unread postby GJ51 » 26 Feb 2014, 03:43
viewtopic.php?f=17&t=1012
The ability to read is so precious. :geek:
GJ51
Unread postby daneren2005 » 26 Feb 2014, 03:48
In his defense he asked the question before that thread was created
Sent from my Nexus 5 using Tapatalk
daneren2005
Developer
Developer
Unread postby vviudez » 26 Feb 2014, 15:52
ok.. thanks...
And yes... the link was not set yesterday....
Sorry for the inconvenience...
vviudez
Return to Announcements
Users browsing this forum: raidflex and 1 guest
