[Solved] Clean up Media, and Search Functions dont work
Mission accomplished!
silversix311
Unread post by silversix311 »
Hey guys,
I have been trying to figure out whats going on here, but my Madsonic can no longer search for files. It shows less and less files in the search, but i can navigate manually through madsonic and find everything i need. Im not really sure whats causing this. I also tried doing a Clean Up and Refresh on my media folders to see if that would fix the problem but im getting an error. Any help would be appreciated.
Exception	org.springframework.dao.TransientDataAccessResourceException
Message	PreparedStatementCallback; SQL [select max(id) from media_file where last_scanned != ? and present]; S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where last_scanned != ? and present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where last_scanned != ? and present]
Java version	Oracle Corporation 1.7.0_51
Operating system	Windows 8 6.2
Server	jetty/8.y.z-SNAPSHOT
Memory	Used 81 of 283 MB
Stack trace	org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select max(id) from media_file where last_scanned != ? and present]; S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where last_scanned != ? and present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where last_scanned != ? and present]
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607)
	at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:768)
	at net.sourceforge.subsonic.dao.AbstractDao.queryForInt(AbstractDao.java:97)
	at net.sourceforge.subsonic.dao.MediaFileDao.markNonPresent(MediaFileDao.java:657)
	at net.sourceforge.subsonic.controller.CleanupSettingsController.handleRequestInternal(CleanupSettingsController.java:85)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where last_scanned != ? and present]
	at org.hsqldb.jdbc.jdbcPreparedStatement.executeQuery(Unknown Source)
	at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:648)
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:591)
	... 69 more
Re: Trying to clean up Media, and Search Functions dont work
it looks you have a rare corrupted database problem. (http://sourceforge.net/p/hsqldb/bugs/853/)
try to delete your DB folder to recreate your database.
i will research to upgrade HSQLDB to the latest 2.3.2 release.
silversix311
I actually fixed it myself just a few moments before you posted >.<
I moved my db folder, let it create a new one then dragged in everythin but the larger DB file. It recreated it and kept my settings and everything still looks ok. Just glad i didnt have to recreate everything... I have alotta users and about 400gb of music... i hate resetting things up.
Thanks for the quick reply tho! :)
These users thanked the author silversix311 for the post:
