Replacement for dyndns
Other related stuff
Unread postby skopo » 09 Apr 2014, 05:49
Just got email this morning that dyndns free will be canceled for 30 days now.
What do you use for dns forwarding?
I've been using dyndns 4-years now (because its free)
I'm using subsonic.org forwarder for madsonic but other services will be problem.
What would be replacement?
What are you using?
skopo
Has thanked: 11 times
Been thanked: 20 times
Re: Replacement for dyndns
Unread postby madsub » 09 Apr 2014, 10:45
madsub
Has thanked: 2 times
Been thanked: 21 times
Unread postby gurutech » 09 Apr 2014, 21:38
x2 on the no-ip.com - that's what I'm using. I do pay like $12.95 for 2 years of extra domain names, as I use more than just the 3 they let you use for free, and I use some of the "non-free" domain names they have available.
Has thanked: 12 times
Been thanked: 131 times
Unread postby skopo » 10 Apr 2014, 06:18
Thanks now my router is paired to no-ip without any problems.
I'm running tomato so I had quite list what to use.
skopo
Unread postby justin » 19 Jun 2014, 02:11
skopo wrote:Thanks now my router is paired to no-ip without any problems.
I use freedns.afraid.org with tomato. Have never had any probs
justin
Unread postby kornkid5622 » 05 Jul 2014, 21:53
i was just going to post freedns.afraid.org i started using them when Dyn started doing the "you have to login every 30 days to keep your domain" thing and it works just fine, i'm using it with DD-WRT, so it's compatible with most custom router firmware it seems :)
kornkid5622
Has thanked: 4 times
Unread postby DoCC » 18 Dec 2014, 08:49
mh i have enabled the ddns option at my regular domain provider.
i have several domains registred via regfish.com ...
so i have , ok not free, but included : ) limitless ddns entries avail.
ip4 ip6
cname alias mx ptr
everything one can use building his own network ; P
DoCC
Has thanked: 41 times
Been thanked: 71 times
Unread postby utopian » 23 Dec 2014, 16:31
duckdns
utopian
Has thanked: 1 time
Been thanked: 19 times
Return to Off Topic
