Madsonic doens't start anymore after upgrading on OSX
Unread postby skopo » 15 Dec 2014, 18:06
For some reason Madsonic doens't start anymore after upgrading 5.2 Beta2.
How to troubleshoot?
skopo
Has thanked: 11 times
Been thanked: 20 times
Re: Madsonic doens't start anymore after upgrading
Unread postby Madevil » 15 Dec 2014, 18:20
Please provide more Infos:
  • used operating system
  • used CPU architecture
  • used server memory
  • used Java version
  • Madsonic Build before
  • Madsonic Build upgrade to
  • Error messages
  • Log entries
it is very difficult to make diagnoses without any clues. ;)
Support guide: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
Has thanked: 1338 times
Unread postby skopo » 15 Dec 2014, 18:47
  • used operating system: OSX 10.10.1
  • used CPU architecture: i5 sandybridge x64
  • used server memory: old one 64.4 MB / 81.1 MB
  • used Java version: Java 7. update 71
  • Madsonic Build before: 5.0.3830
  • Madsonic Build upgrade to: 5.2 Beta2
  • Error messages: N/A just doens't start. no process
  • Log entries: How to find on osx?
skopo
Unread postby Madevil » 15 Dec 2014, 18:58
I wish also such a Mac for testing, but need to test it all even virtually. :(
Maybe the new Madsonic starter script doesn't work right on Yosemite.
Infos about the OSX installer can found here: http://beta.madsonic.org/installation.jsp#mac
Unread postby skopo » 15 Dec 2014, 19:24
I think that might cause the problem.
But problem remains with my older mac on work that runs 10.9.4. (test bench for everything. Should be re-installed from very beginning)
I have tried to get standalone running but problem remains the same (even with older builds) it just won't start.
skopo
Unread postby Madevil » 15 Dec 2014, 19:49
Did you use the new OSX installer?
Please try the following:
open Terminal.app
cd /Applications/Madsonic.app/Contents/Resources/Java/
java -cp madsonic-booter.jar org.madsonic.booter.Main -mac
you should see something like this:
Dez 15, 2014 7:47:04 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@67abaab: display name [org.springframework.context.support.ClassPathXmlApplicationContext@67abaab]; startup date [Mon Dec 15 19:47:04 CET 2014]; root of context hierarchy
Dez 15, 2014 7:47:04 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from class path resource [applicationContext-mac.xml]
Dez 15, 2014 7:47:04 PM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@67abaab]: org.springframework.beans.factory.support.DefaultListableBeanFactory@4a8acc0c
Dez 15, 2014 7:47:04 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@4a8acc0c: defining beans [deployer,frame,controller]; root of factory hierarchy
Using WAR file: /Applications/Madsonic.app/Contents/Resources/Java/madsonic.war
Extracting webapp to /Library/Application Support/Madsonic/jetty/5420
2014-12-15 19:47:04.651:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2014-12-15 19:47:07.831:INFO:/:Initializing Spring root WebApplicationContext
Dez 15, 2014 7:47:07 PM org.springframework.web.context.ContextLoader initWebApplicationContext
INFO: Root WebApplicationContext: initialization started
Dez 15, 2014 7:47:07 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing Root WebApplicationContext: startup date [Mon Dec 15 19:47:07 CET 2014]; root of context hierarchy
Dez 15, 2014 7:47:08 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
INFO: Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
Dez 15, 2014 7:47:08 PM org.springframework.security.config.SecurityNamespaceHandler <init>
INFO: Spring Security 'config' module version is 3.2.5.RELEASE
Dez 15, 2014 7:47:08 PM org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser parseInterceptUrlsForFilterInvocationRequestMap
INFO: Creating access control expression attribute 'permitAll' for /**
Madsonic starts and you can see the whole start procedure, after some seconds the Madsonic tray icon should appear.
Not all error/warnings will be logged into the file, maybe some strange errors can only found on the debug console.
Madsonic logfile can be found here: /Library/Application Support/Madsonic/madsonic.log
Re: Madsonic doens't start anymore after upgrading on OSX
Unread postby skopo » 16 Dec 2014, 14:32
Test server gives this when running terminal command.
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/madsonic/booter/Main : Unsupported major.minor version 51.0
   at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
   at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
   at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
   at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
skopo
Unread postby Madevil » 17 Dec 2014, 17:30
This error mean, your system use the internal Apple JAVA6 engine as default. But Madsonic need to run the installed Java7.
You can override this with the environment setting JAVA_HOME
Literally all you have to do is:
echo export "JAVA_HOME=\$(/usr/libexec/java_home)" >> ~/.bash_profile
and restart your shell and try it again.
Now this comand should return the right path
echo $JAVA_HOME
/Library/Java/JavaVirtualMachines/jdk1.7.0_72.jdk/Contents/Home
or
java -version
java version "1.7.0_72"
Java(TM) SE Runtime Environment (build 1.7.0_72-b14)
Java HotSpot(TM) 64-Bit Server VM (build 24.72-b04, mixed mode)
Unread postby DoCC » 17 Dec 2014, 18:17
if only v6 is installed, install v7 additionally.
then list your java versions again in the terminal.
if there is still v6 listed,
then you have to alter the default engine.
in linux there is a way like "update-alternatives --config java"
then you can select the new default ...
but as we all know apple wants it the hardway ...
this is a way to switch it in osx
http://superuser.com/questions/490425/h ... s-x-10-8-2
DoCC
Has thanked: 41 times
Been thanked: 71 times
Unread postby skopo » 18 Dec 2014, 08:12
That did the trick!
I had installed Java 1.6 after 1.7 for some applications.
I thought 1.7 should stay as default.
Now running like dream. (Had to rebuild DB but that was expected anyway)
skopo
Return to Bug Reports 5.x
