Something wrong with DB
Unread postby digitalirony » 28 Oct 2014, 14:03
My DB keeps breaking. To the point where I have to re-install subsonic/re-initialize a new DB to get it to work....
I have tried pulling just the user accounts of the DB and putting it in the new one so that I can move them over...but that seems to break it.
The errors I am seeing is:
Error
Exception   org.springframework.jdbc.BadSqlGrammarException
Message   PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
Java version   Sun Microsystems Inc. 1.6.0_27
Operating system   Linux 2.6.32-5-amd64
Server   jetty/8.y.z-SNAPSHOT
Memory   Used 38 of 191 MB
Stack trace   org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
   at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607)
   at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
   at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
   at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
   at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:177)
   at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:96)
   at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:66)
   at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:153)
   at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
   at java.lang.Thread.run(Thread.java:679)
Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
   at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
   at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
   at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
   at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
   at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
   at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:591)
   ... 72 more
Anyone shed some light on this? Is some asshat sql injecting me with bad data into my DB? Is there a file I downloaded with something that isn't escaping correctly?
digitalirony
Re: Something wrong with DB
Unread postby digitalirony » 28 Oct 2014, 16:31
So, after digging into this more....
This issue seems to only happen in chrome when I login as the non admin user, while using apache proxy.
If I login directly to port 4040(without using apache), or if I login as the admin user, there is no issue.
Also, If I login with firefox, also no issue.
Also, this is 5.0, I tried to update to 5.1 and 5.2, however the debian packages provided are missing quite a bit of the files(such as tomcat.....)
digitalirony
Unread postby DoCC » 18 Dec 2014, 09:02
i have used the apache proxy since 4.6 with chrome as main browser. no problems.
but i have always run ubuntu x64 not pure debian.
i did install madsonic via dpkg .
updates via standalone files.
never any major problems like this.
DoCC
Has thanked: 41 times
Been thanked: 71 times
Return to Bug Reports 5.x
