QNAP x31 (ARM) installation
Unread postby boblablah » 19 May 2015, 20:46
I was able to get this running, albeit not perfect on a QNAP NAS not using the prebuilt x-19 or intel packages for QNAP.
I did this by installing the JRE-ARM package, and the TOMCAT server package from QNAP.
Then I downloaded the WAR archive from the madsonic downloads site and deployed via TOMCAT manager.
I did this all by following this site and using google's translate function.
(replace locations and folder names of subsonic with madsonic)
https://www.brainmauke.de/?p=272
it has a how-to for deploying the WAR into tomcat but it's all german.
Anyways... my problems are as follows:
Changes to the installation are not persistent. When I change the admin password it works until the app is restarted in tomcat. When I add media folders and index the music, it's fine until after restart, then the path is no longer there.(likely permissions but not sure where this is stored or how)
Also can not find transcoders... i put them in /var/madsonic/transcode/ and restarted the app, still no go. Also there is a lock file created in the DB folder that is not removed.
boblablah
Re: QNAP x31 (ARM) installation
Unread postby VikingOy » 20 May 2015, 19:53
There's a QNAP qpkg package available for Madsonic that should run on all their ARM NAS. Have you tried that?
VikingOy
Has thanked: 3 times
Unread postby boblablah » 23 Jun 2015, 17:54
I am hoping madevil would be so kind as to create an x31 arm qpkg for the qnap.
boblablah
Unread postby VikingOy » 31 Mar 2016, 20:26
boblablah wrote:I did this all by following this site and using google's translate function.
This link is dead. If you have a copy of the description (file) - cold you provide a copy from Dropbox or similar?
VikingOy
Return to Support 5.x
Users browsing this forum: Bing [Bot] and 0 guests
