Madsonic Newsletter 07/2015
Re: Madsonic Newsletter 07/2015
Unread postby humbahumba » 19 Jul 2015, 11:13
I would like to test, too.
especially
*) Sonos tests
in addition I should manage to test these things, too:
*) dynamical scanning
*) Transcoding tests
*) GUI workflow tests
*) Performance tests
*) Stability tests
EDIT: btw I can#T reach beta.madsonic.org or sub-pages
EDIT2:--> up again
humbahumba
Unread postby chali » 20 Jul 2015, 02:04
DoCC wrote:2 vCPU ( 3,0 Ghz ) , 2048 RAM ESXI based , works without any of your mentioned probs ..
After the license server went online again the server is really responsive =)
i'm still have the problem that i have to delete the data base after every restart =( (no changes are made to madsonic, and its installed on a fresh installed ubuntu x64.
have you tried any app to the server? i get "wrong version" on Madsonic app, subsonic app , and on Dsub
and the last error i get is if i ad a new source i get this error page.
(got any idea on how to fix it?)
/Regards
Exception java.lang.IllegalArgumentException
Message Non-positive period.
Java version Oracle Corporation 1.8.0_45
Operating system Linux 3.16.0-43-generic
Server jetty/8.y.z-SNAPSHOT
Memory Used 90 of 261 MB
Stack trace java.lang.IllegalArgumentException: Non-positive period.
at java.util.Timer.schedule(Timer.java:286)
at org.madsonic.service.MediaScannerService.schedule(MediaScannerService.java:98)
at org.madsonic.controller.MusicFolderSettingsController.onSubmit(MusicFolderSettingsController.java:108)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:415)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:387)
at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:272)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:268)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:855)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:982)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:1043)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:865)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
chali
Has thanked: 89 times
Been thanked: 66 times
Unread postby tycoonbob » 20 Jul 2015, 18:32
Grabbed the RPM for 6.0.6740 and installed it on a clean CentOS 7 VM with 2 vCPU and 512MB RAM. Also running OpenJDK 1.8.0. Installed nfs-utils, added my music share in /etc/fstab, mounted it. When in MadSonic and added my music library, and let it run a full update. At this point, I rebooted the server.
I then verified I could play music from the webui, and I could. Went to Settings > Sonos and checked the box, and hit save. "MadSonic" showed up as a service in my Sonos controller, and I was able to add the service with a username and password. However, in Sonos, when I browse to the "MadSonic" Service, it just says "Unable to browse music".
Couple observations; no player was created for Sonos. I believe with the latest SubSonic builds, a Sonos player is created. Also, the logs threw a couple errors relating to my Sonos Boost (ip is 172.16.1.22). Here are the logs:
[7/20/15 1:22 PM]   INFO   HsqlDaoHelper   Checking database schema.
[7/20/15 1:22 PM]   INFO   HSqlSchema02   Avatar templates updated successfully.
[7/20/15 1:22 PM]   INFO   HsqlDaoHelper   Done checking database schema.
[7/20/15 1:22 PM]   INFO   HsqlDaoHelper   Checking HSQLDB version: 2.3.2
[7/20/15 1:22 PM]   INFO   UserService   Checking User accounts ...
[7/20/15 1:22 PM]   INFO   MediaScannerService   Automatic index scan: every 1 day(s), NEXT: Tue Jul 21 03:00:00 EDT 2015
[7/20/15 1:22 PM]   INFO   UPnPService   Checking UPnP service...
[7/20/15 1:22 PM]   INFO   PodcastService   Automatic Podcast scan: every 24 hour(s), NEXT: Mon Jul 20 13:27:46 EDT 2015
[7/20/15 1:22 PM]   INFO   UPnPService   Disabling UPnP/DLNA media server
[7/20/15 1:22 PM]   INFO   UPnPService   Checking UPnP service - Done!
[7/20/15 1:22 PM]   WARN   NetworkService   No UPnP router found.
[7/20/15 1:22 PM]   WARN   VersionService   Latest Version Info is outdated.
[7/20/15 1:23 PM]   INFO   VersionService   Resolved latest Madsonic final version to: 5.1.5200
[7/20/15 1:23 PM]   INFO   VersionService   Resolved latest Madsonic beta version to: 5.1.5240
[7/20/15 1:23 PM]   INFO   SonosService   Found Sonos controllers: [172.16.1.22, 172.16.1.41, 172.16.1.37]
[7/20/15 1:23 PM]   INFO   SonosServiceRegistration   Disabling Sonos music service, using Sonos controller IP 172.16.1.22, SID 244, and Madsonic URL http://172.16.1.130:4040/ws/Sonos
[7/20/15 1:23 PM]   WARN   SonosService   Failed to enable/disable music service in Sonos controller 172.16.1.22: org.apache.http.client.HttpResponseException: Method Not Allowed
[7/20/15 1:23 PM]   INFO   SonosServiceRegistration   Disabling Sonos music service, using Sonos controller IP 172.16.1.41, SID 244, and Madsonic URL http://172.16.1.130:4040/ws/Sonos
[7/20/15 1:23 PM]   INFO   SonosServiceRegistration   Sonos controller returned: success!
[7/20/15 1:23 PM]   INFO   SonosServiceRegistration   Enabling Sonos music service, using Sonos controller IP 172.16.1.22, SID 244, and Madsonic URL http://172.16.1.130:4040/ws/Sonos
[7/20/15 1:23 PM]   INFO   SonosServiceRegistration   Enabling Sonos music service, using Sonos controller IP 172.16.1.41, SID 244, and Madsonic URL http://172.16.1.130:4040/ws/Sonos
As of right no, Sonos is a no go for me.
tycoonbob
Has thanked: 2 times
Been thanked: 14 times
Unread postby Ksmoove » 20 Jul 2015, 19:16
I'd like to test
    Performance tests
    Stability tests
    LDAP
    and GUI
Ksmoove
Has thanked: 1 time
Unread postby Ksmoove » 21 Jul 2015, 03:46
LDAP works as smoothly as ever. I see there is a new field in the LDAP part of the control panel called "LDAP group role attribute". What would this be used for exactly? My assumption is that it will have something to do with the user access groups
Ksmoove
Has thanked: 1 time
Unread postby nh5 » 22 Jul 2015, 02:44
How can I join the testing as well? I have active group of users eager to test. I also have a huge media library, Sonos and have been awaiting LDAP integration. Let me know how I can help!
nh5
Has thanked: 1 time
Been thanked: 8 times
Unread postby boco » 22 Jul 2015, 23:53
/Regards
I also have the above mentioned issues with adding additional sources. Also some other small GUI settings not holding throughout. Non of the mobile apps will communicate with the 6.x version as stated.
boco
Has thanked: 69 times
Been thanked: 30 times
Unread postby warllo » 27 Jul 2015, 18:03
I would like to test version 6.0 I can test all of the items listed below.
*) Stability tests
warllo
Unread postby onechance13 » 04 Aug 2015, 07:30
Hi I would like to test it on my Asustor NAS I ported the pervious version across to the NAS and it is happily running on it. I will give detailed feedback once ported on any problems I come across.
Sent from my A0001 using Tapatalk
onechance13
Unread postby Ksmoove » 17 Aug 2015, 05:57
Getting this error when scanning for multiple folder sets
[8/17/15 12:54 AM]   ERROR   MediaScannerService   Failed to scan folder.
Ksmoove
Has thanked: 1 time
Unread postby billzkid » 18 Aug 2015, 17:35
Couple of findings:
1. Play top tracks stopped working today for me (it worked till now for a couple of days)
2. Play all ads all the tracks twice to the playlist
billzkid
Has thanked: 4 times
Unread postby billzkid » 20 Aug 2015, 15:24
Ok, I believe last.fm problem is because they're redesigning the site. Hope that they don't break the API
billzkid
Unread postby tycoonbob » 21 Aug 2015, 16:13
Just installed 6.0.7110.
Sonos is still a no-go. When I connect to my Sonos system, and try to browse my library, it says "Unable to browse library".
Here is logs for when it fails: http://dumptext.com/g2M51B7h
This is a primary feature for me, and I can't pay for this product if this feature isn't working. For now I am running MadSonic 5.2 and SubSonic 5.3 trial (since it has Sonos support working), and I have to re-install SubSonic 5.3 every 30 days. I'd much rather have working Sonos in MadSonic 6.x, and pay for that (a one-time cost would be preferred, or at least a lifetime option).
tycoonbob
Unread postby dsig » 21 Aug 2015, 16:28
I would love to test it ..
Speed
Stability
UI
I only have 160K+ tracks if that is a limiting factor
dsig
Unread postby Soleurs » 22 Aug 2015, 16:36
dsig wrote:I would love to test it ..
Speed
Stability
UI
You can easily help test Madsonic 6.0, but be aware you may lose your playlists and user accounts, since upgrades from 5.x are not supported. Make a backup of your current Madsonic installation folder before installing Madsonic 6.0, just in case. The download is available at http://beta.madsonic.org
Soleurs
Unread postby VikingOy » 09 May 2016, 20:35
chali wrote:i'm still have the problem that i have to delete the data base after every restart =( (no changes are made to madsonic, and its installed on a fresh installed ubuntu x64.
/Regards
I'm now on 6.0.7860, Ubuntu 14.4 (QNAP Linux Station), and the above error pops up immediately after setting Media path.
Any idea what to do to fix it?
VikingOy
Has thanked: 3 times
Unread postby kirkeby » 27 Oct 2018, 21:12
I just got the same server crash 3 years later.
It happens when the 'interval' property of a media folder is set to 'Never' which is probably equivalent to 0 in the code. It is clearly a bug.
ole
kirkeby
Previous
Return to Announcements
