Android Client Early Adopter Program
Android Client for Madsonic
Re: Android Client Early Adopter Program
Unread postby drrighteous » 03 Aug 2014, 04:58
Unusual issue here. Using latest 5.6 beta along with Techdemo III.
When attempting to play (stream) FLAC files from the client, files transcode and start downloading fine, however playback doesn't start until nearly the entire file is downloaded; and when it does start, the position starts halfway on the file, almost like the client thinks it's been playing all along since early buffering.
I'm able to slide the position back to 00:00 and it does correctly start at the beginning. I've been able to duplicate this behavior multiple times as I mostly ripped my personal library straight from cd to flac.
--David
drrighteous
Has thanked: 1 time
Been thanked: 9 times
Unread postby aramisathei » 29 Aug 2015, 05:35
I've been getting an issue with it saying the login credentials for the server are wrong even though the same credentials work fine on the web interface.
Anyone else seeing this?
aramisathei
Has thanked: 2 times
Been thanked: 5 times
Unread postby Madevil » 29 Aug 2015, 21:26
Can you be more specific about your configuration!
INFO: viewtopic.php?f=2&t=1520
Has thanked: 1338 times
Previous
Return to Client
