Chromecast broken?
Chromecast broken?
Unread postby fenderson » 06 Mar 2015, 07:45
Hi!
I cannot stream using chromecast.
It shows a "Madsonic" page on the chromecast with the status bar scrolling.... forever.
Anybody else with the same issue?
fenderson
Re: Chromecast broken?
Unread postby DoCC » 06 Mar 2015, 20:03
... more infos !
DoCC
Has thanked: 41 times
Been thanked: 71 times
Unread postby hibby50 » 30 Mar 2015, 00:31
same issue here. i think im on 5.1 stable im gonnna go to 5.2 beta to see if it works
hibby50
Unread postby hibby50 » 30 Mar 2015, 00:36
mine is doing the same. 5.2 beta
hibby50
Unread postby avpap » 08 Sep 2015, 06:42
I have the same problem as the OP. I am running MADSONIC 5.1.5240.20150506.1214 as a docker app on an unraid server. I have tried to use both the madsonic server web ui (through chrome) and the android Dsub app to stream to my chromecast and neither seem to be working. My chromecast is working fine as other apps (youtube, plex, pocketcasts etc) can stream content to it.
Please tell me if you need anymore info,
Thank you very much!
avpap
Unread postby gurutech » 08 Sep 2015, 21:12
I'm using the Madsonic 5.7 "beta" version, with VLC "beta" as my video player, and even though there are no icons for Chromecast (that I can find), I was able to go into the chromecast app on my phone (android) and "cast screen", and when I play a video, it opens VLC which detects the chromecast and starts playing the video.
Has thanked: 12 times
Been thanked: 130 times
Unread postby avpap » 10 Sep 2015, 11:40
I solved my problem and want to write the solution in case someone else had the same issue. I am using dsub as the android player. As it turns out the problem was that madsonic was using by default ssl with a self signed certificate. Chromecast "doesn't like" self signed certificates. As soon as I disabled ssl everything worked fine!
avpap
Return to Bug Reports 5.x
