Media/Libary Tool Collection
Which tools do you use and like best?
Media-Monkey
38
15%
MP3-Tag
54
21%
Tag&Rename
25
10%
Jaikoz Audio Tagger
6
2%
MusicBrainz Picard
41
16%
LastFMPlus - Extended Picard Tagging
9
3%
LastFM Tag Extractor
4
2%
Foobar 2000
37
14%
Beets
23
9%
Axone
0
No votes
MPTagThat
0
No votes
Other
21
8%
Total votes : 258
Unread postby Madevil » 10 Jan 2013, 02:13
It's time to spot out the best tools for Media-Libraries, tagging, rename, restructure, information and other related stuff around your music stuff.
if you think i forgot the best tool, feel free to post your favorites. :wink:
Has thanked: 1339 times
Re: Media/Libary Tool Collection
Unread postby magikbus » 02 Mar 2013, 16:19
I have used MP3 Tag before but they stopped supporting it for Windows 7 and higher, so I started using Tagscanner which I think is much better
http://www.xdlab.ru/en/
magikbus
Unread postby Otherland » 05 Mar 2013, 14:46
magikbus wrote:I have used MP3 Tag before but they stopped supporting it for Windows 7 and higher, so I started using Tagscanner which I think is much better
MP3Tag does support Windows 7, and 8..so what do you mean ?
Otherland
Unread postby chali » 13 Mar 2013, 01:06
I use Media Center Master (I've basically only have movies on my server)
marty, you should add movie to the server name :D
/Chali
chali
Has thanked: 89 times
Been thanked: 66 times
Unread postby ForSSux » 02 Apr 2013, 18:13
Hi There,
All these tools are fine but what I don't find is a tool that let me import xml data into a mp3 or the database.
Not all files have a expanded metadastructure like mp3
Normal wav's for example.
There are very expensive DAM 's like Dalet which use a structure like create a title in a database and in this database we can have all sorts of metadata.
Other library music publishers use a xml scheme
It would be neat to be able to batch import a xml scheme into a mp3.
It would be neat to be able to batch import the same xml scheme into the database used by madsonic.
Kind Regards
Guy Forssman
ForSSux
Has thanked: 27 times
Been thanked: 19 times
Unread postby richardap1 » 14 May 2013, 14:05
MusicBee, has very good tagging tools.
richardap1
Unread postby breakolami » 14 Jul 2013, 12:57
Hello a long time ago when I use Windows my preffered app was Mediamonkey
Since 2008 my computer works with Kubuntu and now I use Easy Tag
Sorry I can't post link because I'm new
breakolami
Has thanked: 3 times
Been thanked: 10 times
Unread postby newburns » 17 Jul 2013, 15:30
What I can't find is a Linux Server based tagger. I run a lot of command line server VM's, and most of the music is not on Windows Shares, so taggers in Windows Desktops don't work. I am looking for something that possibly has a WebGUI to sort through items that need confirmation, but will run in the background, sorting, tagging, and renaming.
I guess it can match the track time, title, artist, and if any don't match, you must confirm in a webgui (Something like this)
Anything exist? For RedHat/Centos?
I primarily run SME 8.0 (contribs.org)
newburns
Been thanked: 11 times
Unread postby Lars » 04 Jul 2014, 00:42
and as far as the linux world goes, take a look at puddletag - nearly mp3tag like. very useful.
cheers, L
Lars
Has thanked: 30 times
Been thanked: 29 times
Unread postby kornkid5622 » 04 Jul 2014, 23:58
i use a combination of Foobar2000 and Ultimate Tagscanner, as well as Album Art Downloader (to download album art of course) all great tools to keep your library organized :)
kornkid5622
Has thanked: 4 times
Unread postby Saklasklas222 » 07 Jul 2014, 18:27
newburns wrote:What I can't find is a Linux Server based tagger. I run a lot of command line server VM's, and most of the music is not on Windows Shares, so taggers in Windows Desktops don't work. I am looking for something that possibly has a WebGUI to sort through items that need confirmation, but will run in the background, sorting, tagging, and renaming.
http://beets.radbox.org/ ... would be nice to have this incorporated inside madsonic.
Saklasklas222
Has thanked: 1 time
Unread postby gr8pa2 » 19 Oct 2015, 13:36
I learned to use Beets, that I setted up on my NAS server to scan my music download folder and tag, rename and move my files accordingly to my wished data structure. My music is now perfectly sorted, tagged and named like never before.
Madsonic will scan daily my library but I will manually update if I wish to listen to a newly added album right away.
Since Beets a a command line only tool, if the autotag ships the file because it is not recognised properly, I will SSH to my server to reply to the tagger request.
Looked for a long time for the perfect setup and I got it now with Beets and Madsonic.
gr8pa2
Been thanked: 5 times
Unread postby tetnenal » 22 Oct 2015, 10:24
+ 1 for puddletag
beets integration would be awesome though
tetnenal
Has thanked: 1 time
Unread postby andyfitter » 24 Oct 2015, 12:06
Bliss?
Www.blisshq.com
Runs as a server with a web interface. Very good.
andyfitter
Unread postby Matt Zornig » 19 Feb 2017, 07:02
f2k is the swiss army knife.
In combination with the DiscoGS tagger, its almost unbeatable.
(mp3tag is praised in the f2k forums, but I don't like switching my musicplayer just for tagging the files)
Been thanked: 20 times
Return to General
