I am a long-time subsonic user considering to switch to madsonic and I need help in getting it up and running... I removed my subsonic installation (saved the /var/subsonic folder) and installed madsonic using the .deb package. After installation, when I try to go to localhost:4040 I get the following error. It appears like some kind of bad database issue but I don't understand why this is happening with a fresh madsonic installation.
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded, group_id, locked, comment from user where username=?]; nested exception is java.sql.SQLSyntaxErrorException: user lacks privilege or object not found: GROUP_ID
Java version Oracle Corporation 1.7.0_85
Operating system Linux 4.2.0-16-generic
Server jetty/8.y.z-SNAPSHOT
Memory Used 25 of 316 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded, group_id, locked, comment from user where username=?]; nested exception is java.sql.SQLSyntaxErrorException: user lacks privilege or object not found: GROUP_ID
at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.java:92)
at org.madsonic.dao.AbstractDao.query(AbstractDao.java:91)
at org.madsonic.dao.AbstractDao.queryOne(AbstractDao.java:129)
at org.madsonic.dao.UserDao.getUserByName(UserDao.java:78)
at org.madsonic.service.SecurityService.getUserByName(SecurityService.java:168)
at org.madsonic.controller.MultiController.login(MultiController.java:101)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:471)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:408)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:139)
Caused by: java.sql.SQLSyntaxErrorException: user lacks privilege or object not found: GROUP_ID
at org.hsqldb.jdbc.JDBCPreparedStatement.(Unknown Source)
at org.hsqldb.jdbc.JDBCConnection.prepareStatement(Unknown Source)
at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1447)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:583)
... 88 more
Caused by: org.hsqldb.HsqlException: user lacks privilege or object not found: GROUP_ID
at org.hsqldb.ExpressionColumn.checkColumnsResolved(Unknown Source)
at org.hsqldb.QueryExpression.resolve(Unknown Source)
at org.hsqldb.ParserDQL.compileCursorSpecification(Unknown Source)
at org.hsqldb.ParserCommand.compilePart(Unknown Source)
at org.hsqldb.ParserCommand.compileStatement(Unknown Source)
at org.hsqldb.Session.compileStatement(Unknown Source)
at org.hsqldb.StatementManager.compile(Unknown Source)
... 92 more
