https does not work
https does not work
Unread postby illumilore » 17 Dec 2015, 22:31
After following the instructions to enable https by changing the config file line for the args to MADSONIC_ARGS="--port 4040 --https-port=4443 --init-memory=300 --max-memory=1050", when accessing the https port, the web browser is never able to connect.
illumilore
Re: https does not work
Unread postby gurutech » 17 Dec 2015, 22:57
If you are running this on Linux, you will need to open the 4443 port on the OS firewall.
Has thanked: 12 times
Been thanked: 131 times
Unread postby jake- » 18 Dec 2015, 10:32
illumilore wrote:After following the instructions to enable https by changing the config file line for the args to MADSONIC_ARGS="--port 4040 --https-port=4443 --init-memory=300 --max-memory=1050", when accessing the https port, the web browser is never able to connect.
Maybe a typo because https port is 443 not 4443?
https://your.host/ for 443
https://your.host:4443/ for 4443
only to be sure this is what you had in mind ...
jake-
Has thanked: 15 times
Been thanked: 18 times
Unread postby illumilore » 21 Dec 2015, 00:56
4443 is what I set the https port to be in /etc/sysconfig/madsonic, since 443 is already used. I have checked the firewall to make sure that is open. In the madsonic_sh.log, there is no mention of it running on port 4443, only on 4040.
illumilore
Return to Bug Reports 5.x
