Unread postby Oxize » 09 Apr 2016, 10:17
Can you show any logs?
You can SSH with Putty on your Synolgy. On directory var/packages/Madsonic/target are the logs.
https://www.synology.com/en-global/knowledgebase/DSM/help/DSM/AdminCenter/system_terminal
Oxize
Has thanked: 1 time
Unread postby carlosarze » 09 Apr 2016, 15:10
I wasn't able to install , there is nothing on that path....
the only thing is a log in the root directory
08.04.16_12:23:02: found Java in /volume1/@appstore/java8/ejdk1.8.0_77/linux_i586/jre
08.04.16_12:23:02: Can't find a folder named 'Madsonic' in your public folder.
08.04.16_12:23:02: Please check your public folder and make sure there is a folder called Madsonic (with Capital M) in it. Or select 'No' if you don't want to restore anything and just install Madsonic normally
carlosarze
Has thanked: 1 time
Unread postby carlosarze » 14 Apr 2016, 20:32
@Madevil is there any hope to see Madsonic on Synology DSM 6.X ?
carlosarze
Has thanked: 1 time
Madsonic Folder not found --- Solution?
Unread postby HolgerWill » 14 Apr 2016, 23:35
I had the same issue. Madsonic folder was not found in public.
I opened the spk file in 7zip.
In folder "scripts" I opened the file installer.sh with notepad++
Then I modified line4 to..... PUBLIC_FOLDER="/volume1/public"
After that the installation run through
HolgerWill
Re: Madsonic Folder not found --- Solution?
Unread postby carlosarze » 15 Apr 2016, 15:47
HolgerWill wrote:I had the same issue. Madsonic folder was not found in public.
Thank you very much using 7zip did the trick I didn't realize that using winrar was not saving the modified installer.sh
Anyway Madsonic is installed now and seems to be working ....
Thanks again !!!
carlosarze
Has thanked: 1 time
Unread postby muiz » 16 Apr 2016, 00:22
Thanks again !!!
can you please upload your file?
muiz
Has thanked: 4 times
Unread postby madschwall » 17 Apr 2016, 11:20
Thanks, the trick with editing installer.sh did the job.
I had to reboot the NAS then everthing is running like a charm.
madschwall
Unread postby muiz » 17 Apr 2016, 15:13
Never mind i got it. it installed fine now thank you.
EDIT: It started but the page wont show up. So its still not working for me.
EDIT 2 : Reinstalled DSM now it works.
muiz
Unread postby HolgerWill » 19 Apr 2016, 11:26
madschwall wrote:I had to reboot the NAS then everthing is running like a charm.
Yes this is right. I forgot to mention this point.
Rebooting is necessary.
Nice to see that I could help some members here.
HolgerWill
Unread postby Oxize » 22 Apr 2016, 20:08
Note! A new version is available. Download Madsonic 6.1.8220 HERE.
Any changelog of this madevil?
Oxize
Has thanked: 1 time
Re: AW: Madsonic Server 6.x Synology-DSM 6.x NAS Plugin
Unread postby Madevil » 22 Apr 2016, 20:54
Has thanked: 1339 times
Unread postby Oxize » 23 Apr 2016, 10:40
What is refactor left-panel?
Is the playlist on left-panel fixed also with this update?
Oxize
Has thanked: 1 time
Unread postby softsmoke » 02 May 2016, 13:32
Hello all
i installed the latest version. Now i cant see my library in DSUB. can somebody tell me why? its says No data!!
/Softsmoke
softsmoke
Unread postby Oxize » 04 May 2016, 18:46
lol i am afraid to update now.
Oxize
Has thanked: 1 time
Unread postby Siutsch » 10 May 2016, 19:52
softsmoke wrote:Hello all
/Softsmoke
Same here.
Siutsch
Has thanked: 2 times
Unread postby Madevil » 10 May 2016, 20:57
Rest API fix is included in the last build 8280.
Backup Database .. HOW?
Unread postby HolgerWill » 13 May 2016, 12:25
Everytime I deinstall the old version in DSM I select "Make Backup in Public"
But while installing the new version with "restore Backup" it is not working.
It is all blank new. No restoring of anything!!
Is there any solution?
HolgerWill
Unread postby carlosarze » 09 Jun 2016, 22:45
Installed the last version and does not work ...
HTTP ERROR: 503
Problem accessing /. Reason:
Service Unavailable
carlosarze
Has thanked: 1 time
Unread postby Oxize » 18 Jun 2016, 12:39
Anyone else who tried the new version?
Its really hard to get it working. It doesnt install out-of-the-box anymore.
I am using 6.1.8190 atm, but last time i had such a hard time to get it installed again. Dunno how to get the new version on it, and will it be the same pain installation as last time?
Oxize
Has thanked: 1 time
Unread postby tofuSCHNITZEL » 28 Jul 2016, 18:24
after manually creating the Madsonic folder in public the install worked fine with Madsonic6.1-B8550-048.spk
should the videostreaming work? I only get a white screen with following text:
http://NAS:4040/hls/hls.m3u8?id=4&playe ... tRate=3000
tried in FF, IE and Edge. the latter two also display the whole interface not correctly so starting the stream is a little difficult (lowest frame takes up about 80% of screenspace)
VLC is installed
DS1813+
DSM 6.0.1-7393 Update 2
tofuSCHNITZEL
Has thanked: 1 time
PreviousNext
Return to Synology
Users browsing this forum: Google [Bot] and 0 guests
