Madsonic Docker support
Re: Madsonic Docker support
Unread postby opty » 24 Jan 2016, 18:18
first of all thanks for the Docker image, it was real easy and simple to set it up on my synology NAS.
i actually for the first time was able to stream video to isub using this latest image but i also noticed that the url of the streams are exposed and anyone can actually stream any file by guessing the stream ID and without login.
is this something on my setup or some permission not being set correctly on madsonic side? it seems the madsonic admin account is being used for the stream
thanks
opty
Has thanked: 1 time
Unread postby opty » 27 Jan 2016, 19:55
just a little update.
it seems like this is true on any setup and server version and has nothing to do with synology or docker. this happens even on madsonic/subsonic demo site.
one of the reason i noticed this was the extreme number of hits/played on one of my video series on my server over 1500 in matter of days and i only have like 10 user with 3-5 of them being active users!
opty
Has thanked: 1 time
Unread postby Madevil » 27 Jan 2016, 20:09
with the new Madsonic 6.1 branch, authentication stream endpoint with token will solve this issue.
http://beta.madsonic.org/pages/changelog.jsp#6.1
Has thanked: 1338 times
Unread postby opty » 28 Jan 2016, 16:21
This is a real good news! and the 6.1 version already looks promising and slick. it seems like we are moving away from flash. :thumbsup:
opty
Has thanked: 1 time
Unread postby adrianp » 23 May 2016, 18:04
Hi and thanks for working on the Docker support. I had a question regarding the docker images for Unraid. Why are there 4 different ones? And why would I choose one vs another? Just trying to figure out which one I should use. Im currently on Unraid 6.1.9.
Thank you,
Adrian
adrianp
Unread postby arckosfr » 08 Aug 2016, 09:00
I currently using one of my docker image for Madsonic, it's based on Alpine.
Advantage is the weight of the image (around 5Mb for alpine).
Complete size (on serveur is 231Mb) and the actual tag on the hub a around 150Mb.
I think proposing an image based on Alpine can be great :)
Link of my image on the hub : arckosfr/madsonic (can't post URL)
Have a good day !
arckosfr
Unread postby daemon9th » 12 Oct 2016, 18:09
Thanks for the great docker images!
Any chance of getting an update to the madsonic/arch-madsonic branch docker similar to the ubuntu and debian based dockers?
br
daemon9th
Unread postby z-vap » 23 Oct 2016, 15:12
Hey. I was trying to use containers and thought id give this a try. I have a test openmediavault 3.0 VM that I am trying out and just installed their stable docker plugin. I found the madsonic debian image and started it, and a container showed up. But the container keeps "restarting" over and over.
mkdir: cannot create directory ‘/config/media’: Permission denied
mkdir: cannot create directory ‘/config/playlists’: Permission denied
mkdir: cannot create directory ‘/config/transcode’: Permission denied
cp: cannot stat ‘/var/madsonic/transcode/linux/*’: No such file or directory
/var/madsonic/madsonic.sh: 164: /var/madsonic/madsonic.sh: cannot create /config/madsonic_sh.log: Permission denied
Started Madsonic [PID , /config/madsonic_sh.log]
I don't know if its something I did, or if its the image itself, or what. Any ideas?
z-vap
Has thanked: 2 times
Unread postby VikingOy » 15 Nov 2016, 18:51
I'm using a standard Debian Madsonic Image installed in ContainerStation (Docker) on my QNAP TS-453Mini server, and it runs just beautifully.
VikingOy
Has thanked: 3 times
Return to Docker
