I've updates Madsonic to Server 6.2.9080 and there are a few bugs.
1- I still have the same captcha bug with user signup:
ERROR: Stoken expired ...
Need I do something to remove the bug ? Or maybe to disable the captcha ?
2- Language is still in english in the main menu bar. Just playlist is translated
If you need or want I can help you to translate in French & German
Have a good evening.
Cheers
Captcha & Language
Re: Captcha & Language
For the captcha issue, your system clock is out of sync with google which is causing the error.
On Ubuntu, I fixed the issue by running:
Happens every once in a while.
sudo ntpdate -s time.nist.gov
sudo service madsonic restart
