What happened
Madsonic Server 6.x
Maduser
What happened
Unread post by Maduser »
I cant access madsonic outside of my home network. I even purchased the app for my phone and it still only works on my home network.I have a license and been using madsonic everyday outside my home network. Now I can't. Only when I am home. Can someone please help me get it fixed so I can listen to madsonic when I am away from home..
thechez
Been thanked: 9 times
Re: What happened
Unread post by thechez »
Make certain that your router didn't reset and that it's still forwarding the port. It may be that you just had a reset and now the ports aren't being forwarded. That should fix things. Also, make certain those settings are checked under network in the Madsonic menu and that everything is good there.
These users thanked the author thechez for the post:
