Podcast with unicode characters in XML do not work
Unread postby troycarpenter » 13 Feb 2017, 17:16
I have found another podcast that doesn't seem to work with the Madsonic podcatcher. The podcast in question has unicode characters in the XML which seem to cause parsing errors. I have confirmed this by downloading a copy of the XML file locally, removing the XML characters, and pointing Madsonic at the local copy of the XML. The podcast will then process and download as expected.
I will send you a URL to the feed in question.
troycarpenter
Has thanked: 19 times
Been thanked: 50 times
Re: Podcast with unicode characters in XML do not work
Unread postby huggenknubbel » 18 Feb 2017, 02:38
Not only with Podcasts. i also get trouble with Music with Unicode Characters.
i have some Music with ä, ö, ü, "_" and so on. The ID3 Tag - Filescan doesnt list that in the Libary.
huggenknubbel
Has thanked: 4 times
Unread postby troycarpenter » 20 Feb 2017, 00:39
huggenknubbel wrote:Not only with Podcasts. i also get trouble with Music with Unicode Characters.
Yes, I've seen that too with the scanner. I've had to watch the log file and fix any filenames so the scanner would catalog them.
troycarpenter
Return to Bug Reports 6.x
